EM TuningSky Insurance
Results 1 to 8 of 8
    nixy's Avatar
    Mar 2010
    61
    Boost gauge & pod fitting???
    Need to fit boost gauge but where is the grommit through the bulkhead? Also I cant seem to find a A-pillar mount anywhere?
    Can anyone help??
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    your need to buy a ebay A-pillar gauge pod and mod it to give a good fit.
    i found 2 places to put a vac line into the car.
    1. is the place where the bonnet realse cable goes (under the scuttle panel)
    2. passanger side where the wiring loom goes into the car (behind airbox)
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    S3 Paul's Avatar
    Oct 2006
    2,764
    I used the second option. Easy and simple as no cutting was needed.
    I was told the seat leon A pillor pod isnt a mile away from whats needed?
    However i bought mine ready done.
    Noggy Blue 2001 S3
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    i'm not sure about the leon pod. i used a £7 ebay one, and trimmed it to fit. when i had an A-pillar pod
    Aug 2010
    Dumfries, Tartan-land
    203
    I did mine yesterday.
    Open the drivers door and take off the end cover to reveal a fuse box.
    Undo any screws that hold that in and you will gain access into the side of the dash.
    You then need to remove the wipers and scuttle panel.
    Then remove the wiper linkage.
    Once all that is out the way, you will be left with a black box in the scuttle area.
    Take the lid off it and you should see daylight through all the wires in there.
    That will gain you a route for your vacuum hose at least. Let me know if u need any more help mate.
    1998 Audi A3 1.8T Sport (AGU) - Remap, Apexi CAI, Scorpion CAT back, 3" downpipe/Decat, Coilovers, 18" RS4's
    nixy's Avatar
    Mar 2010
    61
    Ok Will give it a try in the morning
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    Chesterfield, Derbyshire, United Kingdom
    612
    Ive got seat leon a pillar double pod in mine
    Gauge pod using seat leon pillar mount
    nixy's Avatar
    Mar 2010
    61
    So fitted it with pics to come ended up mounting on the steering housing till i can get a pillar mount!!!
