Chris NottJMB Retrofits
Results 1 to 13 of 13
    davidniclee's Avatar
    Apr 2011
    west wales
    96
    please please help got a big problem with my clutch
    as above was at a junction earlyer and had my clutch in and then i heard a crack noise like plastic broke,and my clutch pedel was flat on the floor and wouldent come back up, so i pushed the car to the side of road and looked and a peice of black plastic was on floor,anyway got my car back to work and got another black plastic clip which i fitted and then i pressed the clutch and it happend again the plastic broke ,does this mean the slave cylinder as gone or is it the master thats gone, all and any help would be great and very much appreaciated thanks dave
    p.s have got a price of £30 for slave clinder in the scrap yard
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    the price of the slave cylinder is the least of your worries ....its in the gearbox....i think you need a new pedal, loads have happened lately have a look....
    Apr 2011
    west wales
    96
    from what i can gather the slave cyilinder is fixed the the clutch pedel assembley only 3-4 bolts hold it on ,the master cylinder is the hard one iv been told and the slave one meant to be easy but iv no idea so im hoping its the pedel assembley and not the master cylinder
    Lizard-Racing's Avatar
    DTM
    Apr 2011
    Hampshire
    151
    When you say on the floor do you mean in the car? If so its the master cylinder and the easier of the two to do. Genuine are £57ish +VAT
    Alex
    2005 DTM|Quattro|Phantom black|HTA3076 turbo|Pag Parts turbo manifold|INA Engineering custom 8 injector manifold|Custom Garrett 900hp intercooler|Mahle Motorsport 83mm forged pistons|IE Tuscan forged rods|Autotech HPFP|Tial wastegate|S3 Injectors|3" Downpipe and full stainless exhaust|Stage 3 Southbend clutch|AP Coilovers|Ultra Race strut brace|H & R ARBs|Forge 6 pot calipers|Bi Xenons|Multifunction steering wheel|Memory seat|Cruise control|Power fold mirrors|Black 19" Cades Berns|235/35 Toyos
    Apr 2011
    west wales
    96
    Quote Originally Posted by Lizard-Racing View Post
    Alex
    yes inside the car the bloke in the srappy said its the slave cylinder its all one piece with the clutch pedal .
    then the master cylinder is inside or near the gear box thats what he told me he said if the master cylinder has gone th clutch will need changing because hydrolic fluid gets on the clutch he said
    lukejenks's Avatar
    Nov 2010
    57
    its the master cylinder by the pedal. slave is in the box as it is part of the thrust bearing. unfortunately I found this out last week!
    Apr 2011
    west wales
    96
    so whats the chances of it beng the one by the pedal does anyone know or is it more likley to be the one in the gear box
    lukejenks's Avatar
    Nov 2010
    57
    Well when mine went last week you could either have the pedal right up or flat to the floor, so i dont think its the slave cylinder, apparently the pedal is common to breaking, so if you have plastic bits in your footwell its more likely the pedal
    2000 Imola Yellow S3
    Essflee's Avatar
    Mar 2008
    2,007
    From how you explain your problem it's nothing to do with your slave or master cylinder, it sounds like actual peddle is knackered, the crack you heard and the piece of plastic you describe is what happens, do a search, lots of people had the same problem.
    And for the record your local scrap dealer sounds like he hasn't got clue what he's on about...
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,281
    SOunds to me like the good old clutch pedal. Common problem. Mine went on Monday night, see here:
    HELP fitting new clutch pedal
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,281
    Do any of the bits of plastic look like this?
    S3 Build Thread
    darko's Avatar
    Dec 2004
    london, uk
    272
    99% sure it's just your pedal. Mine did it and when I bought a new pedal I saw why ! There's a tab that is folded over and just tack welded, it's that tab that pushes the master cylinder and eventually snaps off. I had my new one welded all the way round before refitting. I posted the whole process but it was about 5 years ago now
    S3 AMK - Revo - Bilstein B8 Dampers - H&R Springs - AH FMIC - And currently in pieces...
    Apr 2011
    west wales
    96
    well iv just fitted a new clutch pedal assembly the master cylinder the lot, bled the system and its working fine thanks for all your help guys very greatful, and in the pic above its the little black bit of plastic that cracked its what holds the white piece in place so thats what the problem was,
    but did have orangey fluid coming out of the master cylinder inside car so changed the lot 2day
    like i said thanks for all the help guys
    thermostat next
