Monster MotorsportEM Tuning
Results 1 to 10 of 10
    day
    Stoke on Dread
    May 2011
    Stoke-on-trent
    32
    Exclamation VW PASSAT SE 1.8 20V ENGINE HEAD AND BLOCK AEB
    I have just brought a AEB head and block out of a Passat I'm only after the head, but everything is there under the bonnet so my question is do I need anything else from the Passat for the head to go on my S3..
    thanks in advance day
    S3 AMK 2001 completely standard...let the work begin
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    Remember to change the camshaft sensor pickup on the belt end of the inlet cam, the AEB cam only has one window whilst the S3 has 4. Simple job, just a 13mm bolt.
    Also if your S3 is AMK/BAM then youll need the cam chain tensiober also as the AEB head is non VVT
    Audi S3 1.9 GT30....
    ....that is all
    day
    Stoke on Dread
    May 2011
    Stoke-on-trent
    32
    nice one MUSH...
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    Im buying a aeb head next week, is the chain tensioner hard to fit?
    MUSH's Avatar
    Jun 2010
    Newcastle
    712
    Nope piece of pee, theres a few guides on the net but i just followed elsawin for removing cams. You only have to remove the inlet cam caps. Youll need a chain tensioning tool though, got mine from GSF for £4! Theres a little bit of info in my thread
    ....that is all
    day
    Stoke on Dread
    May 2011
    Stoke-on-trent
    32
    day
    Stoke on Dread
    May 2011
    Stoke-on-trent
    32
    Hi all
    I manage to get hold of a AEB & AGU cylinder head, I know they are both similar which one do you recommend i keep for my Audi S3 AMK 2001...
    AEB 110,000 MILES
    AGU mileage unknown and needs a woodruff key
    thanks day
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    Random, but did you get aeb head from guildford? I would use aeb.
    day
    Stoke on Dread
    May 2011
    Stoke-on-trent
    32
    No mate i got it from Northampton and the AGU from Bolton....but i did ring one on ebay and he was in guildford/Surrey but it was sold..
    thanks day
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I'd use the AGU.... It's designed to be transverse.
    All in all though, it really won't make a squirt of difference.
    Homer Simpson
Tags for this Thread
