EM TuningChris Nott
    Apr 2011
    east yorkshire .... hull
    oil pressure sensor location
    hi all just a quick one after low oil pressure warnings ive fitted a new oil pick up but befor i start the car i would like to have an oil pressure test ready to go so i know instantly if the problem still persists but i cant seem to see the oil pressure sensor could anybody tell me the location of it. also what pressure should the gauge be reading when i do start it ?
    beachbuggy's Avatar
    Surrey
    1,741
    The only pressure sensor on the car is a switch, which only activates above 1500rpm. It will only flash a light on the dash if the pressure drops. You can fit a pressure sensor on the oil filter and then have a gauge in the car. There is a spare thread hole on top of the oil filter you just need to remove the hex plug and install the sensor. Pick one up from ebay for about £30 in PSI.
    S3KO4's Avatar
    Aug 2009
    London
    850
    located on the right side of the oil cooler, under the inlet manifold, you will need a 24 spanner to remove it. you also need to remove the oil feed on the cooler to the turbo. cost me £14 from audi last month
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
LinkBacks (?)
  1. 30th June 2012, 04:33
