AH FabricationsJMB Retrofits
    Apr 2009
    Preston
    245
    2002 S3 - Headunit lights / Fuse issue possibly?
    Has somebody please got the foggiest clue as to why my Headunit lights have gone completely out.
    Only those are effected. Not the instruments, air con lights etc just solely the Headunit buttons.
    Will replace the fuse + see if this clears it up. Any idea what number fuse this is?
    Thanks,
    Joe
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    It says on the back of the fuse panel mate
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Does the headunit still work ok?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Twice in 2 1/2 years my stereo has stopped working just needed the fuse taking out and putting back in again
    2002 S3 REVO
    Apr 2009
    Preston
    245
    Ok chaps. Cheers. Its recently been taken out however nothings been changed / swapped.
    Had Andymac install one of his Subwoofers and therefore just tiny niggly things have started happening since. No dram though.
    Will check it, pull it out / clean it up + put it back to see if that sorts the little sod out...
    Westle: Yes it does (fully) just the front panel ie: Search button / 1,2,3,4,5,6 station buttons on the actual radio itself have completely gone out. Only noticeable at night obviously however its annoying all the same.
