EM TuningVolks Autos
Results 1 to 7 of 7
    S3 Owner
    Feb 2009
    Aberdeen
    414
    Who has R32 front brakes?
    I got mine fitted a while ago now and only just remembered that the brake pipes didnt fit back in to the little clip bit. Did you change to braided hoses or use the r32 lines?
    Sean
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    Do you mean the little clip bit on the shock? My braided lines dont fit that clib either so I've just cable tied them to the shock.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    S3 Owner
    Feb 2009
    Aberdeen
    414
    No not on the shock, its actually part of the inner lining, behind the shock if you like..
    gez
    S3 hunter
    Sep 2009
    Middlesex
    98
    I used the oe r32 lines. I used a bar to slightly open up the 2 prongs which the pipe sits in. Then used the oe clip to secure it. They also fitted perfect on the shock with no cable ties needed.
    S3 Owner
    Feb 2009
    Aberdeen
    414
    I'm pretty sure its the 2 prongs your talking about is where its not fitting for me using the r32 lines.. Will have a look the week after next and see if there's room for some 'persuasion'
    Still open to other ideas though!
    gez
    S3 hunter
    Sep 2009
    Middlesex
    98
    No other ideas needed. Only needs the tiniest bit of moving.
    S3 Owner
    Feb 2009
    Aberdeen
    414
    Cool cheers for that!
