Volks AutosBadger5
Results 1 to 7 of 7
    Dec 2004
    burton on trent
    122
    a problem with gearboxs
    hey all just got my car back from dealers and whilst in there had a nosey in the workshop in there to my horror found out about a problem with early (MK1) A3s gearbox. (NOT QUATTRO)
    most boxes used were mk4 golf boxes used and the problem with these is that the crown pinion in the diff are not bolted on but riveted these can shear and punch holes through the bell housing which in all asspects kills the box and clutch and leaks all gear oil out. so all if you have a leak from gearbox (fairly major leak) this is proberly the reason why.
    P.S new box 1400 approx
    Dec 2004
    burton on trent
    122
    Re: a problem with gearboxs
    well all the gear box refurbishers i spoke to say this is a common problem and is the main reasons for there work and exchange on the boxes
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Welcome to the world of VAG gearboxes. This has been a problem since year dot for VAG.
    There is a bolt kit available for them which solves the problem. God only knows why VAG don't fit the bolts at the factory and still insist on fitting rivets!!
    Here are pics of what happened to my Golf's gearbox last year :-(
    http://homepage.ntlworld.com/kevin.y...fGoBoom001.jpg
    http://homepage.ntlworld.com/kevin.y...fGoBoom002.jpg
    Mmmmmm, nice hole!!
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    [ QUOTE ]
    Mmmmmm, nice hole!!
    [/ QUOTE ]
    Not good [img]/ubbthreads/images/graemlins/frown.gif[/img]
    I take it the bolt kit is an Audi fit job though?
    Dec 2004
    burton on trent
    122
    no a good mechanic can do it but its an expensive job for little to be done catch 22
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    [ QUOTE ]
    [/ QUOTE ]
    I was just thinking get it done before it may be happens.
    Dec 2004
    burton on trent
    122
    not sure if they sorted the problem for the 1.8t as think its a different box set up to the 1.6 can anyone confirm this
