JMB RetrofitsVolks Autos
Results 1 to 26 of 26
    Aug 2009
    Costa del Cardiff
    535
    </3 car wont start...fml
    My cars developed a fault and now it wont start Turn the key to stage 2 in the ignition, everything is fine, turn it to stage 3 to start the car and nothing happens, the engine/ignition makes no attempt to start. Car has been fine since I bought it, this is the first time its played up. All the electrics work, its just the car wont even tick over, which leads me to think it might be the ignition, but this has developed just today apparently. Drove the car round town for an hour or so then put a £10 in it, drove it a mile down the road to my mates house, the car was turned off for no more than 15 minutes and now it just wont start. Any ideas/advice would be much appreciated!
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Alternator?
    Check all wires too and from Mate..
    IF IN DOUBT FLAT OUT---iF U AINT RUBBIN U AINT DUBBIN
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    are the lights dimming when trying to start?
    Feb 2011
    southampton
    229
    dose the car sound like its trying to turn over as my car wouldnt start and ended up being coil pack and it kept blowin the fuse for fuel pump relay check these as well based on amk
    audi s3 2001 amk 210bhp, forge 007p
    Aug 2009
    Costa del Cardiff
    535
    Will have to check tomorrow, the cars left at my mates. Im hoping its just a lose wire or something as the roads down his street are quite rough. I'll check the lights dimming too. The thing is the car literally makes no sound when you turn the ignition the entire way. When at stage 2, the dash says "OK" on the DIS as normal. =/
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    You should have tried bump starting it, or jump starting it. The first places to look are the battery and the startermotor.
    99 S3 Absolute red
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Check the main fuse strips on top of the battery, as well as loose terminal clamps on the battery
    Aug 2009
    Costa del Cardiff
    535
    Cheers for the suggestions guys, will give it a look over tomorrow I'm hoping its just a loose connection and nothing expensive
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    I had this after I refitted the battery, turns out I didn't tighten the terminals up. Never had it since
    Aug 2009
    Costa del Cardiff
    535
    Nice one Karl, it must be something along those lines, because the car is getting power to the radio, windows etc
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Mine went to position 2, with all lights on, then when I went to start,boom, off and nothing
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    729
    do people still manage to put a tenner worth of petrol these days
    sorry couldn't resist that !
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    Apr 2010
    Widnes Cheshire
    404
    Umm starter motor related, possibly!
    DC
    His: 2001 1.8T AUM. Hibiscus Red Pearl Effect - Hers: 2002 1.8T AUM. Metalic Silver.
    Sep 2005
    Derbyshire
    180
    I had this recently and it was my starter motor. My symptons were the same as yours (if your lights dim its isn;t the starter motor) if they dont dim it may well be the same issue as me.
    Aug 2009
    Costa del Cardiff
    535
    Bump started the car and it runs fine, but still wont start via key in ignition. Having a mate look over it tonight to hopefully find a loose cable somewhere. Also the lights do dim when trying to start via ignition =/
    EDIT: Faulty starter motor and low battery
    S3KO4's Avatar
    Aug 2009
    London
    850
    You are wasting your time, by looking anywhere else than what I am telling you mate. the guys here are very helpful but non had this symptom when I described it a month ago. so end it up checking everything to no avail. until I took it to a specialised today who found the fault at the ignition module (switch) part number is 857440480 from ECP. cost me £11.40 but had to pay £30 for the diagnosis and I did the work myself. removed the steering wheel to get access to the ignition. and then two small flat head screws hold it in place covered by red wax. just remember to mark the steering angle. and disconnect the battery when removing the airbag.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Aug 2009
    Costa del Cardiff
    535
    Hmmm fair enough mate I'll tell my mech tomorrow cheers! If it is the starter motor, would a starter motor off any 8L A3 work on an S3?
    S3KO4's Avatar
    Aug 2009
    London
    850
    it's not the starter motor.
    Sep 2005
    Derbyshire
    180
    As your lights are dimming on the "3rd" stage of the starting procedure I am inclined to agree with S3KO4, my symptons were very similar except my lights didn't dim and because of it was the starter motor.
    Aug 2009
    Costa del Cardiff
    535
    Thanks for the suggestions lads. Haven't resolved the issue as I haven't touched the car since the end of the week. I'll pop down Audi tomorrow morning as there only across the street, explain the issue and suggest your theory S3K04. I'd rather "waste" £11 on a module just to rule it out than spend £100+ on a starter motor and not have needed too. Will let you know how it goes.
    thegoal007's Avatar
    Apr 2008
    surrey
    729
    If your likely to take it to Audi then....
    Firstly I would expect they will want more than £11 for the part and probably significantly more to replace it.......I think.
    May 2011
    bham
    might be starter motor.
    May 2011
    bham
    sorry mate did not realise its been suggested already didnt read all new 2 this.
    Aug 2009
    Costa del Cardiff
    535
    Got the ignition switch from ECP. Will fit it and see if it makes a difference. Otherwise I'll grab a starter motor this week.
    Aug 2009
    Costa del Cardiff
    535
    Solenoid in the starter motor is faulty New starter motor it is then £££!!!
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Quote Originally Posted by JoeD View Post
    How did you find out after? Forgot to ask you when i saw you on monday.
    I'll be ready soon so will bell you when i've left mine and grab you.
    P.s remember keep £30 for the shoot AND GET YOUR CAR FIXED
    Dark Vader Half sibling - MyThread
