Sky InsuranceAH Fabrications
    Jan 2005
    Derbyshire UK
    9
    S-Line Badge! Will it fit?
    Hi everyone, I've got a S-line badge which I plan on fitting on my 2003 A3 grille! On quick inspection
    in the dark it looks a pretty fiddly job as you don't seem to be able to get to the back of the grille to attach
    the clips! Will it fit or am I going to have to use sticky back plastic, cable ties and superglue?????????
    [img]/ubbthreads/images/graemlins/confused.gif[/img]
    /Maffy
    jesters3's Avatar
    The Shire's
    1,516
    Re: S-Line Badge! Will it fit?
    dealer or call VAG Part and find tou what the process would be?
    nervus's Avatar
    Apr 2004
    1,155
    Get a 2003 S3 (or quattro if they are similar) grille badge and prise the 'S3' off with a small flat driver (its just sticky taped on) and then stick the S-line badge in its place with trim tape.
    The S3 one just pushes into place with little metal spring clips, its getting the swines off again which is difficult.
