Page 2 of 2 FirstFirst 12
Results 41 to 75 of 75
Like Tree3Likes
Thread: * DIY Injector cleaning how to * Pic Heavy
  1. #41
    Jul 2009
    Cambridgeshire, United Kingdom
    427
    Wow. I'm getting an extra 3mpg, and that's mixed town and motorway. Definitely worth doing.
    Current
    Porsche Cayman S
    Gone but not forgotten
    Audi S3:Blueflame TBE; 3" blueflame downpipe; Forge 007p; jabbasport custom map; Badger 5 TIP v1, various bushes, N249 Bypass, Stack Boost Gauge, Junior GT Brembo brakes, tarox 2 part discs, DS2500's
  3. #42
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    Bump for the part numbers on the seals. Also anyone know what that ebay seller was that does the injector seals?
    S1LFH, thats a good increase, hows the car drive?
  4. #43
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    A035 906 149 A A0602 O Ring £3.31 each + VAT !!!
    I remember buying some injector O rings for my old GTE, about 65 pence each.
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
  5. #44
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    WTF, how much.
    Is that for the top or bottom ones livewire?
  6. #45
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    haha ye I bought 4 before, biggest waste of money ever. Dani, go to a motor factors and just get the same size o rings for peanuts.
    I think top and bottom are the same size on my injectors, not sure on others.
    I got my cleaner on Saturday, its bloody tiny lol. From looking at the pics it looks pretty big lol. Not bothered at all as it does the job intended but I thought it would be much bigger from looking at pics of it lol.
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
  7. #46
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    WTF, how much.
    Same size for top and bottom mate, I was in a rush to get these (11am on a Sat morning) so just bit the bullet and went to the steelers
  8. #47
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,854
    Wait until you ask for a price of an injector
  9. #48
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    Cheers lads, ill try to find the size of them. Would anyone happen to know the size o ring needed .
  10. #49
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    My mates just had one go on his 170 tdi a3, cost £850 to replace it, lmfao, told him he was a right mug for going to the stealers.
  11. #50
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,715
    I thought i would start a new thread for this, so it does not get lost in the other one.....
    This is a guide to ultrasonically clean your injectors, plus fuel pressure regulator... AKA, FPR thats what i will be calling it on this how to, for obvious reasons.
    I have tried to do the how to, so a completely clueless person can understand, so dont think im being patronizing ....lol
    Safety first,,,,you are messing with the fuel system, there is likely to be a little fuel lost in this process, so bear that in mind....
    So to start off this is the fuel rail, where all the attention will be
    By d121m at 2011-05-14
    and the FPR...
    Start off by unclipping the electrical wiring loom
    There are 3 clips holding the loom to the rail and simply push off
    Next is The FPR pull the hair clip type thing away from the FPR.... Then pull the vacuum pipe of the FPR
    Then get a cloth and put it over the FPR then twist and pull at the same time,(be prepared for some fuel spillage) it may be tight and require some patience but it will eventually give in, put it somewhere safe for now.
    next is to get the little clips off the top of the injectors that hold each connector on,
    a bit fiddly, i got a small screwdriver and eased them up, make sure you dont drop anything as it will be lost forever.....put all 4 safe and pull the connectors off each injector,
    Next is to remove the rail from the manifold...(it is still connected by the fuel pipes no need to touch these)
    there are 2 cap head bolts to undo (again make sure you dont drop them)
    and the other one...
    After these are removed and kept safe its time to pull the rail up with the injectors,
    once free of the manifold you can get to the injector clips (yes more clips) these simply slide out
    a pic of one out....
    take all 4 out and keep the safe, then pull the injectors out of the rail, sometimes the O ring keeps in the rail ... just hook it out and put it back on the injector
    once all 4 are out you are ready for the fun part....Bath time...
    injectors before their clean
    Next prepare your ultrasonic cleaner....
    I used very hot water and a cap full of james sea solution and put the cleaner on max 480 secs
    Get the injectors in along with the FPR and watch the crap come out of them...
    when it is finished the water looks like this:
    Take them all out and shake then let dry for half an hour or so,....Clean injectors!!
    Refitting is a reverse of the how to, being careful not to lose anything make sure everthing goes back the way it came off, start the car and check for leaks.....
    My car took a lot of starting (well third attempt) this time round must have got a bit of air in...
    so dont worry if it does not fire up as usual when first started...
    TOOLS NEEDED
    allen keys
    small screwdriver
    small pliers
    ultrasonic cleaner + fluid Ultra 7000 Ultrasonic Cleaner : Ultrasonic Cleaners : Maplin
    *on offer at the moment*
    little vid showing the cleaner doing its magic....
    http://img837.imageshack.us/img837/9379/8jp.mp4
    Hi Dave sorry to hijack, what size is the blue pipe you used on your N249 bypass and FPR is it all 4mm inside diameter or is it larger on the FPR, Is it just standard silicon pipe on the FPR or fuel resistant and is there fuel going through that blue pipe on the top of the FPR or is it just a vacuum pipe, and lastly what type of clips have you used Cheers mate
    Thanks chris
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
  12. #51
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    and the FPR...
    TOOLS NEEDED
    allen keys
    small screwdriver
    small pliers
    Thanks chris
  13. #52
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I got 3mm internal fits very snug...you dont really need clips on, i just used the ones that came off...standard silicone no fuel goes in them
  14. #53
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    Cheers Dave I was just confused as that pipe was going into the top of the FPR.
  15. #54
    Sep 2006
    Sunny Suffolk
    552
    Planning to have a go at this over the weekend. What size allen key(s) do I need s3dave?
  16. #55
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    5.5mm allen key I think I used.
    Ive just done mine, took less than 5 min to get everything off and in the cleaner, also cleaned the rail too while everything was drying. I cleaned mine twice (480 seconds each) and the first time you couldnt even see the injectors once finished but I think that is down to the surface dirty too. The second time the solution was still quite clean when finished. Will give it a drive later and see how it feels. Oh mine started first time like normal.
    For sale
    PM for info.
  17. #56
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    Woohoo just done mine not as hard as I thought stated straight away after too, iv also done the N249 bypass so next is the catch can I think
  18. #57
    Sep 2006
    Sunny Suffolk
    552
    Thanks S3 Nattie.
    Would that be the same size as the bolt thats used for the AIT/IAT sensor (near the throttle body)? I'm about to head out, but haven't got time to check my allen keys first!
    Also, do you need an especially long allen key?
    Sorry for all the questions!
  19. #58
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Was either a 5 or 5.5mm allen key for the 2 bolts and the IAT sensor is probably the same.
    Use a long nose allen key to undo the 2 bolts for the fuel rail.
    For sale
    PM for info.
  20. #59
    Aug 2009
    Costa del Cardiff
    535
    Nathhhhhhhhhh when I can pop down to do mine??
  21. #60
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Bring it round in the week and we will log your car also. I cant tell any difference if im honest. See if my MPG changes once ive driven it enough.
    Ive been using it for cleaning mine and my families jewellery and it work very well for that lol.
    For sale
    PM for info.
  22. #61
    Aug 2009
    Costa del Cardiff
    535
    If it works well bro why not lol. Ok I'm free until Thursday, whens a good day for you? Hopefully my MAF has bedded in then, to be honest Since I've fitted it I havnt driven the car hard just because I haven't had enough fuel in it lol!
  23. #62
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,854
    I've done my throttle body as well,I'm doing a good 4 extra miles per gallon.
  24. #63
    Mar 2011
    Exeter
    90
    Quote Originally Posted by voorhees View Post
    What have you done to your throttle body voorhees? alignment??
  25. #64
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    Hell have took it off and cleaned it.
  26. #65
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by vanilla_ice View Post
    A bit late now SOS but it's 5 mm
  27. #66
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,854
    Quote Originally Posted by jk_s3 View Post
    He'll have took it off and cleaned it.
    Yes did that,DV service will be next
  28. #67
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    I've got the cleaner but no solution and its eems like online only.
    Has anyone just used washing up liquid? Or this home made solution:
    How to make a Homemade Ultrasonic Cleaning Solution | eHow.com
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
  29. #68
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    Quote Originally Posted by Sam_ View Post
    I wouldn't use washing up liquid as I can imagine it getting quite frothy! Water on its own should still clean it quite well as it's the ultrasonic waves that do all the cleaning work. I'm doing my injectors again this week in preperation for the Ring trip.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  30. #69
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    really must get round to doing this on the track car. got the cleaner and solution, but just havn't got round to it! I reckon they'll be pretty dirty after 206 000 miles!
  31. #70
    Westy's Avatar
    Dec 2008
    17,264
    Get it done in the next 2 weeks mate, you'll be amazed. It only takes an hour to get all the injectors off, bathed a few times, then all back together.
    S3 Build Thread
  32. #71
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I would use warm water with a spoonful of vinegar,..., like westy says it will break down the crap anyway just do a few cycles..
  33. #72
    deeman88's Avatar
    Watch this space...
    Aug 2011
    SE London
    418
    cheers, will give this a go on the weekend and keep you posted.
  34. #73
    Aug 2010
    30
    Done this it works a treat
  35. #74
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Bump, anyone around London with a cleaner? Fancy getting this done!
  36. #75
    May 2014
    Any chance of getting the photos back up, they seem to have disappeared?
    sportquattro likes this.
