Monster MotorsportChris Nott
Results 1 to 7 of 7
    AudiS3Quattro's Avatar
    Jan 2009
    201
    S3 making strange noise VIDEO included!
    Just got my car back from the garage, clutch has been replaced, new drop links, new wish bone bushes, new anti roll bar bushes tracking has been done and a new ball joint, but took the car out tonight and when i put my foot down and dont change gear, just keep the car at high revs and back off the acceleration just letting the engine slow me down, i get this strange noise, it almost like a buzzing/vibrating noise, i have added a video, any feed back would be much appreciated!
    2003 BAM Nogaro Blue S3, Revo Stage 2, Approx 270BHP Miltek Exhaust With THS De-cat, Neuspeed P-Flow, Forge Split-R DV, 19" Rail Daytona's 9'' Rears, 8'' Front, Stretched Tyres, Euro Look, 20mm H&R Rear Wheel Spacers, 10mm Front Wheel Spacers, H&R Springs, Chrome Mirrors, Piano Black Dash, Black Recaro Heated Leather, Xenon Headlights, LOW and WIDE!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Dont want to alarm you but s3gaz had a similar noise when his bearings went in the turbo, basicaly the comp wheel was moving about an inch on the shaft, easily checkable with the tip off...
    Other than that check your heat shields behind the bulk head and underneath above the cats....
    I hope its something easy....
    Jan 2009
    201
    thanks for the quick reply, to be honest it sounds like its coming from the cat area, if it were the turbo, would there be any symptoms on spool up and boost?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Sounds like a heat shield to me....
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Well there wasnt on his car, no oil loss or spool issues, He just took the tip off and the play was shocking...A good inch in and out, no up and down movement.....
    It would soon have been catastrophic im sure....he has gone hybrid now
    hopefully in your case its simple...
    crazychris's Avatar
    Oct 2010
    Nottinghamshire
    93
    Hi bud my 1.8TS was doing this the other week turns out the studs on the chassis where the nuts screw in place to hold the heat shields up the threads had rusted but nothing tie wraps couldn't fix and now she's as quiet as a mouse apart from the nasty perished rear axle bushes lol
    Jan 2009
    201
    thanks for the help everyone, i will check both options out tomorrow!
