Monster MotorsportVolks Autos
    Jan 2005
    Wthat S3 came with can-bus?
    Hi all,
    Looking into buying an S3 - with the view to retro fit the Navigation Plus, Doing a lot of research before I purchase! Wthat S3 came with can-bus?
    Basically I see a few references to my00, my01 etc - Are these reference to the year made - I understand that I would need the facelift model.
    I understand that to enable DiS cluster info (sat nav+) the car has to support can-bus? - <font color="green"> Did can-bus appear in 2001 S3's? </font>
    thanks for your input!
    Jan 2005
    Re: Wthat S3 came with can-bus?
    [ QUOTE ]
    Jazz, mines a 2001 S3 with satnav factory fitted.
    The S3 doesn't use CAN for diagnostics (http://www.ross-tech.com/vag-com/canbus.html) , so I guess it doesn' have it (could be wrong tho)
    [/ QUOTE ]
    Do you have the sat info display on the DIS Cluster?
    thanks
    Nov 2004
    Berks
    46
    Yep, as far as I know they all do.
    Jan 2005
    Thanks Planky - Dink I would love to hear form you [img]/ubbthreads/images/graemlins/smile.gif[/img] PM sent
    Bushey, Herts
    58
    The "old shape" did not have CANBUS (Pre-2000). Check before you buy.
