As there are a few of these threads about I started to wish I'd done one showing my progress from standard S3 to the slightly modded S3 I have now. So, I thought I'd go through all my started threads and try to bung all the relevant stuff together so it's all in one place instead of being dotted about.
I bought my Ming Blue S3 on 2nd December 2008 from a mate of mine that didn't get time to drive it as he had 2 other cars and a work van. I paid £6K for a 2002 BAM with 107K miles on it. The owner before my mate had done a lot of motorway miles on the car as he owned a house in London and one in Manchester.
Here's a couple of pics from the weekend I picked it up. Cleaned, clayed, and polished:
Car was completely stock at this point except for a forge 007P DV
It wasn't long before the modding bug took its grip thanks to you lot and this forum
I got myself a ChippedUK remap first which, with the help of VCDS I recorded the following before/after results:
STANDARD
Boost = 11.5 PSI
BHP = 221
Torque = 227 lbft
MAPPED
Boost = 20 PSI
BHP = 257
Torque = 270 lbft
The next few mods were boring subtle ones such as smaller ariel and black grill surround. Also smoothed the standard airbox:
And the results from smoothing:
Did a few trips to the Ring too:
It was really till last year when I started doing some of the bigger mods on the car. After the above trip to the Ring I realised that the standard S3 brakes were made of cheese and it was pretty dangerous to drive on a track. I ended up braking in the middle of corners as they were so bad and ended up with some rear out slides on a few bends.
Before the next Ring trip I had done my brakes. Brembo Max discs, Ferrodo DS2500 pads, motul RBF6000 fluid, and HEL braided lines. The difference on track was unbelievable:
This year has seen quite a bit more activity on the modding front and the introduction of the "Late Night Mechanics":
Started off by tackling the filthy engine bay and the rotting rubber hoses:
First up we rigged up a light so we could strip the car outside and use the garage for spray painting and cleaning.
And so we began to remove parts:
Fuel rail/injectors off and coil packs out:
Rocker cover off and inlet mani off:
Injectors in the bath:
Mani masked:
Mani painted:
Rocker cover painted:
TB painted:
Ooops! The hole I put in the charge pipe by removing the bracket:
Ran out of paint for the charge pipe so it needs another coat or two:
22Likes
LinkBack URL
About LinkBacks
2002 Audi S3
2002 Audi A3 1.8TQS
Adolf
