JMB RetrofitsEM Tuning
View Poll Results: What colour S3 Avus for the Track?
Voters
63. You may not vote on this poll
  • Porsche Guards Red
    34 53.97%
  • Kawasaki Green
    29 46.03%
Page 69 of 90 FirstFirst ... 195962636465666768697071727374757679 ... LastLast
Results 2,721 to 2,760 of 3584
Like Tree124Likes
Thread: W3STY's Progress Thread
  1. #2721
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    by my maths, the 550's will only need to be adapted 13.6% to be within that 25% limit of the 380 map.
    Can you show me how you've worked that out in a Carol Vordaman style Countdown way?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  3. #2722
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,299
    550/380 = 1.44
    take away the 1.25 adaption...
    i get 19% :P
    TD5 Land Rover Defender build
  4. #2723
    Westy's Avatar
    Dec 2008
    17,264
    550/380 = 1.44
    i get 19% :P
    I'll take your word for it
    S3 Build Thread
  5. #2724
    "Stick a V8 in it!"
    15,299
    plus its a breach of copyright to mess with Revo code anyway...
    <tuffty/>
    Doesnt that also apply to Revo modifying Bosch/Audis code in the first instance
  6. #2725
    Reesy's Avatar
    East Sussex
    3,604
    550/380 = 1.44
    i get 19% :P
    Quote Originally Posted by Westy View Post
    Even so, it's within 25%
  7. #2726
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Not if they have paid for it...
    <tuffty/>
  8. #2727
    beachbuggy's Avatar
    Surrey
    1,741
    Westy.
    I'll set my Krkte and other fuel maps back to stock tomorrow morning and I've got a 40 minute drive , I'll see how it goes and look at the lft's for you and see what the score is.
  9. #2728
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by beachbuggy View Post
    Westy.
    That's very kind Dan cheers. Be good just to see the data.
    S3 Build Thread
  10. #2729
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    question, when we say the ecu will adapt the injectors +/-25%, do we mean it will effectively lower the 550's at 3bar to 412.5cc?? or can do if it needs to??
  11. #2730
    Westy's Avatar
    Dec 2008
    17,264
    I would have thought that the 25% + or - would be on the standard 380 injectors as it doesn't know about the 550s other then it's trying to bring the fuel down to what it should be from 380 injectors.
    S3 Build Thread
  12. #2731
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
  13. #2732
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    im failing to understand this adaptation of fuel trims. i keep assuming its the flow of the injectors, but they will be fixed at a certain pressure. so its not like it reduces the flow of them.
    thanks tuffty but the link may aswell be in mandarin.
  14. #2733
    Westy's Avatar
    Dec 2008
    17,264
    Part of me wants to run the 550s just to see what happens but the other part of me thinks I shouldn't bother even fitting them till i'm at the mappers.
    S3 Build Thread
  15. #2734
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Fuel trims apply an adjustment factor to the amount of time an injector is on for... when you log block 002 you will see injector on times... so for example the ECU tells the injector to be on for 18ms in order to provide the right amount of fuel at a given rpm for a metered amount of air... this value is calculated from various tables in the map and from input from various sensors to enable the ECU to meet the required AFR..
    Fitting 550's for example and not adjusting the various tables that 'scale' the injector will result in more fuel being injected for a given pulse time... the ECU sees the AFR go rich so adapts accordingly by incrementing/decrementing LTFT's to apply as a factor in its injector pulse time calcs... The ECU will still calc the injector pulse based on 380cc injectors then apply the adaption to get the final figure...
    <tuffty/>
  16. #2735
    Westy's Avatar
    Dec 2008
    17,264
    I remembered to check block 032 before I cleared the evap error code this time
    This is after 200 miles:
    S3 Build Thread
  17. #2736
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    That is running very rich while running i think mate...
    Have a look here...
    Fuel Trim Info - Ross-Tech Wiki
  18. #2737
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    everyone said a 4 bar FPR gives you 15% more fuel, and yours has pulled out 15%. Sounds good to me. means there's 15% more headroom before the injectors are maxed out
  19. #2738
    Westy's Avatar
    Dec 2008
    17,264
    I keep forgetting I've got that 4 bar lol. Yes what you're saying makes sense. -15% is the ecu removing the extra fuel put in by the FPR.
    S3 Build Thread
  20. #2739
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    I'd be keen to fit new injectors just so they are bloody quieter. They are so loud on these engines? I had some Weber ones that came with my Jenvey bodies on a previous build and they were almost silent!
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
  21. #2740
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by Sam_ View Post
    That's quite interesting, I'd not thought about that before.
    I've got no idea how much quieter the Bosch 550s are, never heard anyone mention it before.
    S3 Build Thread
  22. #2741
    Westy's Avatar
    Dec 2008
    17,264
    Look what just dropped through the door:
    just waiting on my new nozzle from AEM and I should have a fully working WMI setup that doesn't syphon!
    I need to work out the best place to fit this solenoid so that it's easy to wire into the ignition feed as the wires aren't very long! I'm thinking to fit it to the WMI line behind the glove box then run the wires behind the dash to the ignition feed under the steering wheel
    S3 Build Thread
  23. #2742
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Under the bonnet and extend the wires... keep it close to the nozzle...
    Make sure the fittings are done up right else they will leak... seen this before
    <tuffty/>
  24. #2743
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by ;1633584
    <tuffty/>
    It's a lot bigger and heavier then I expected! It does have 2 threaded holes on the bottom so I should be able to mount it to something to hold it in place.
    Do I need to use any specific type of wire?
    S3 Build Thread
  25. #2744
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    According to the website (Methanol Injection Solenoid : DevilsOwn Injection) it uses 15 watts so 15(w)/12(v) = 1.25amps...
    <tuffty/>
  26. #2745
    Westy's Avatar
    Dec 2008
    17,264
    After 2 and a half weeks my new WMI nozzle from AEM still hasn't arrived! I emailed them and the are sending another one, express post this time with a tracking number. With some luck they will both arrive and I'll end up with 2 new nozzles so 1 for a spare
    S3 Build Thread
  27. #2746
    Westy's Avatar
    Dec 2008
    17,264
    A little tease:
    S3 Build Thread
  28. #2747
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,318
    Bosch 550s
  29. #2748
    Westy's Avatar
    Dec 2008
    17,264
    Bosch 550s
    Indeedy. Time to book up a day to get mapped
    S3 Build Thread
  30. #2749
    Westy's Avatar
    Dec 2008
    17,264
    As those of you that follow this thread know i've been on the hunt for some fairly cheap track wheels for my Yoko semi slick tyres I have sitting in the garage. The requirements were:
    - Had to be lighter then 12kgs that the standard 17" S3/TT wheels are.
    - Need to be 17" diameter by 8" wide for my tyres to fit and the extra width will add better handling.
    - Needed to fit directly onto the wheel hubs without spacers as I find this wrecks the handling.
    I've been searching for a while now with the hope of snagging some Team Dynamic Pro Race wheels or any OZ multispoke wheel that is 7-10 kgs in weight. Finding wheels like this is a nightmare. I would find the right offset but the wrong width or i'd find the correct width but the PCD would be for 4 bolts instead of 5 I did consider at one point buying some brand new Pro Race 2.1s in the exact size I wanted but I have to keep reminding myself that I've just bought a house that requires completely decorating and I cant go splashing £450+ on wheels.
    So........ (I expect to get flamed a bit here but) I found some Dotz Mugello wheels. 17"X8" Tick. ET32 5x100 Tick. Lightish at 9.5kgs Tick.
    Only issue with these wheels is that they are currently polished and have a dish. You need to use your imagination a bit here but imagine these wheels refurbed and powder coated in anthracite and with Audi centre caps and I think they'll look quite good.
    As you can see they look much better without the Dotz centres and I've highlighted the worst scuff on them so they should refurb up ok.
    My only concern is that the spoke design wont clear my brembos. The GF is out in my car at the moment so I cant check until she's back.
    S3 Build Thread
  31. #2750
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,379
    I run the mugellos on mine mate. Seems to be plenty of room for larger brakes although I'm not sure how much bigger your brembo's are
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
  32. #2751
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,318
    hmmmmmm, potential good buy if they fit!
    Problem with dished wheels is that it pushes the spokes inwards as you know.....
    Fingers crossed they fit mate. what happened to the Monzas? I might be tempted.
  33. #2752
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,318
    oh no, ignore me, I just remembered they're 7J, so useless :P
  34. #2753
    Westy's Avatar
    Dec 2008
    17,264
    The Monzas were such a better looking wheel and slightly lighter too but were only 7.5J bloody seller didn't have a clue when he advertised them!
    S3 Build Thread
  35. #2754
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Very nice mate that'll certinally do the job
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  36. #2755
    Westy's Avatar
    Dec 2008
    17,264
    Well, the hunt goes on!
    Just did a trial fit and it's not even close spokes touch the calipers and the rim is close to the strut, I give up.
    They would be fine with a 10mm spacer but I don't want that so these are now up for sale.
    S3 Build Thread
  37. #2756
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,771
    Gutted for you mate! Hope you find the right one soon
    <Jay A3 build thread>
    241bhp K03s - R Tech
  38. #2757
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    Gutted for ya mate. Did the monzas fit without fouling anything?
  39. #2758
    Westy's Avatar
    Dec 2008
    17,264
    Nope Monzas hit the calipers too but they were ET35 so I knew it would be pushing it.
    S3 Build Thread
  40. #2759
    Jun 2012
    Essex
    210
    Have you tried calling rimstock directly? I know when I wanted a set of pro race 3 for my track Punto, they done me a good price without tyres as I was buying straight from them.
    Just an idea.
    If they need a bit more persuading, I'm also on the hunt for a set of pro race 1.2 or the newer 1.3 I think. So maybe worth an ask if they will do a better price for 8
  41. #2760
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by Munch View Post
    Just an idea.
    I'd been on their website and they were going to cost me around £450 which I don't really want to spend as I only want some wheels for track use, which is rare at the moment. It might be worth a phone call if there's a few of us I suppose.
    S3 Build Thread
