EM TuningSky Insurance
View Poll Results: What colour S3 Avus for the Track?
Voters
63. You may not vote on this poll
  • Porsche Guards Red
    34 53.97%
  • Kawasaki Green
    29 46.03%
Page 67 of 90 FirstFirst ... 175760616263646566676869707172737477 ... LastLast
Results 2,641 to 2,680 of 3584
Like Tree124Likes
Thread: W3STY's Progress Thread
  1. #2641
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Isn't Welly running monster injectors scaled to work on his ko4 hybrid map still using uni settings?
    630's currently... Welly's map is currently under review
    <tuffty/>
  3. #2642
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,284
    <tuffty/>
    But Tuffty would you recommend I get a full custom map or just get unisetting tweaks done to my stage 2?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  4. #2643
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Quote Originally Posted by Westy View Post
    Custom at this stage mate tbh... especially with all your hardware changes... would be able to get it dialled in perfectly then... unisettings can only do so much
    <tuffty/>
  5. #2644
    Westy's Avatar
    Dec 2008
    17,284
    Just Fitted my AEM filter. Just got to remove the nozzle, flush the system through, fill with water, and leave the nozzle in an empty bucket to see I it's still symphonic. If it is then I shall be buying a check valve.
    Tight fit!
    S3 Build Thread
  6. #2645
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,389
    can't believe you've been having so many problems with your WMI setup man, such a shame!
    How careful are you with what you put into the tank? I'm very careful with mine, only use De-ionised water that Dad filtered, and the methanol, all in super clean containers to ensure no dirt gets in there.
  7. #2646
    RIP S3dave
    May 2004
    nr Glos
    7,199
    he was.. but his is narrow band lambda, his lambda did'nt work anyhow and was disconnected, and fueling on part load was uber rich...
    not ideal..
    bung in bigger injectors on wideband, and it will adapt them settings back out on cruise.. nett result nowhere over time whilst it adapts back out.
    map change of injector scaling to do the job properly
    I have built a map pack for wellys in anticipation
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  8. #2647
    Westy's Avatar
    Dec 2008
    17,284
    The WMI is total cack. 2 nozzles in 6 months. I do however just use tap water.
    Gave the nozzle a little clean:
    Then filled the tank up and primed the system.
    And..... it's still leaking
    Going to leave it overnight and see how much syphons. I think I'll be buying an inline check valve next.
    S3 Build Thread
  9. #2648
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    You want to ask for a full refund, i think they would soon sort you out with a working valve,,
    Mine is exactly the same Prawn, so certainly not a one off..
  10. #2649
    Westy's Avatar
    Dec 2008
    17,284
    Dave I sent you the response I got direct from AEM. It's a joke.
    Here's a little exert for the rest of you:
    "Neil,
    I’m sorry to hear that you are having this issue again. The only thing I can think of would be to run an inline water meth solenoid valve. We don’t make one because we really don’t have this issue with our kits but I’ve seen other users install their own just so they have a peace of mind. I would suggest this. Our water meth line is a standard ¼” push to connect hose. As long as the inline water meth solenoid valve fits ¼” hose it will work."
    We really don't have this issue with our kits hahahaha what a joker.
    S3 Build Thread
  11. #2650
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,389
    What's odd though, is that so many people have used AEM kits without issue.
    Do you run meth and tap water? or just tap water?
    How soon did the problems start? Mine's been on for several months now, and never syphoned a drop, I got paranoid after your issues and often mark the fluid level with tape after a drive, and it's never dropped.
    An inline check valve has to be a solid cure for this though, like Marty runs on his older AEM setup
  12. #2651
    Westy's Avatar
    Dec 2008
    17,284
    My first nozzle was knackered from the start. Was dripping as soon as it was fitted. The replacement lasted 6 months of mainly tap water use but also some meth.
    I'm uploading the video of the nozzle but it's identicle to the first one here:
    http://www.youtube.com/watch?v=1-sq0...e_gdata_player
    S3 Build Thread
  13. #2652
    Westy's Avatar
    Dec 2008
    17,284
    Let's play spot the difference:
    19:30 Tuesday
    06:16 Wednesday
    I'll leave it 24 hours to see just how much has syphoned.
    Any recommendations as to what inline check valve to use? AEM don't do one any more as it's integrated into the nozzle and even if they did do one I wouldn't trust it
    S3 Build Thread
  14. #2653
    RIP S3dave
    May 2004
    nr Glos
    7,199
    DO solenoid is what I have used previously, ign switched
    www.badger5.biz
    bill@badger5.co.uk
  15. #2654
    Westy's Avatar
    Dec 2008
    17,284
    What about just a simple pressure operated check valve like this:
    Methanol Injection : Alcohol Injection : Water Injection : DevilsOwn
    Is this the solenoid you have?:
    The connections are 1/8 not 1/4 so I'm guessing I'll need to by reducers to fit my current piping?
    S3 Build Thread
  16. #2655
    Westy's Avatar
    Dec 2008
    17,284
    S3 Build Thread
  17. #2656
    RIP S3dave
    May 2004
    nr Glos
    7,199
    LOL @ DO check valves.
    worse than aem
    thats the solenoid yes
    www.badger5.biz
    bill@badger5.co.uk
  18. #2657
    RIP S3dave
    May 2004
    nr Glos
    7,199
    this would be more relevant when controlled on/off by the controller.
    we used it just on ign feed, so open all the time the cars running, and just isolates when you switch off (and it potentially siphons)
    I cant see there being any residual back pressure on the pump using it as we did
    www.badger5.biz
    bill@badger5.co.uk
  19. #2658
    Westy's Avatar
    Dec 2008
    17,284
    Thanks Bill, I'll give this solenoid a go then.
    I'll still be sending AEM another snooty email today with pics and videos of their crappy leaking check valve.
    EDIT: Bill, do you use any fancy water?
    S3 Build Thread
  20. #2659
    RIP S3dave
    May 2004
    nr Glos
    7,199
    nope, plain ole tap water, but its not a hard water area where I am, so if hard water where you are I would consider DI or filtered
    www.badger5.biz
    bill@badger5.co.uk
  21. #2660
    Westy's Avatar
    Dec 2008
    17,284
    When I was living at home it was a hard water are but we had a water softener on the line so I used that water. Where I live now isn't a hard water are but I think I'll by a cheap filter of some sort.
    I think the main issue is AEM's crappy check valves.
    S3 Build Thread
  22. #2661
    Westy's Avatar
    Dec 2008
    17,284
    It's nearly been 24 hours since I setup my WMI to see how much it was syphoning and it's astonishing.
    Nearly 2 litres:
    Before:
    After:
    S3 Build Thread
  23. #2662
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    holy cow
  24. #2663
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,389
    You sure your missus hasn't drugged you and stolen the keys and given it a good old thrashing down the bypass?
    I could use that much meth in one evening if I really tried!
  25. #2664
    Westy's Avatar
    Dec 2008
    17,284
    It's a joke isnt it. I'm still worried that even with a solenoid it'll still be syphoning under vacuum when the engine is on. I'll try to get a new AEM nozzle too.
    S3 Build Thread
  26. #2665
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    This WMI lark sounds like Hybrid turbos heh
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  27. #2666
    Westy's Avatar
    Dec 2008
    17,284
    Quote Originally Posted by Sam_ View Post
    Haha you're not wrong!
    S3 Build Thread
  28. #2667
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
  29. #2668
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    These are better tbh...
    Bosch 52LB / 550cc Hi Impedance Injector
    Got all the right data to set them up in the maps and the spray pattern is nicer...
    <tuffty/>
  30. #2669
    Westy's Avatar
    Dec 2008
    17,284
    Nice find mate but I'm after Bosch ones as I think they might be slightly better. Plus at the top of this advert it says shipping in the US.
    S3 Build Thread
  31. #2670
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,389
    Hit and Miss?
    If that's the case, I'm worried. I've had a solid results on both of the above, which I think in theory sets me up for a fall soon :P
  32. #2671
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    They always say that about shipping because they usually include it in the price but I just got a set of ground control mounts off there for $180 shipped here. Bargain. Got a few bargains on there to be honest...
    Yeah, those are the older style injectors too. Those ones Tuffty linked to look better.
  33. #2672
    Westy's Avatar
    Dec 2008
    17,284
    Well, a full meth tank of water syphoned in 36 hours
    I've emailed AEM with pics and my video and I'm demanding another replacement. I won't run the replacement until I have the Devils Own solenoid in place too. This will be a belt and braces setup that will hopefully last a bit longer then 6 months.
    S3 Build Thread
  34. #2673
    Westy's Avatar
    Dec 2008
    17,284
    Had a spare 30 mins today so I thought I'd get round to adjusting some hoses in my engine bay.
    Firstly I needed to shorten the PCV hose from the rocker cover as the T-piece was rubbing on the TIP.
    I then wanted to plumb my DV into the old evap vac nipple. There were two reasons for this. Firstly, it looked ugly blocked off. And secondly, I wanted the DV to have its own vac feed so I could loose the T-piece for my boost gauge and give that it's own vac source too:
    I now have the FPR on its own source, the DV on its own source, and then the boost gauge on its own but with a T-piece for the WMI controller.
    Next job is to remove my shabby inlet mani and paint it kermit green like the rocker cover.
    S3 Build Thread
  35. #2674
    May 2010
    Bedford
    2,877
    I guess you`ve seen this pic then? http://img186.imageshack.us/img186/4...7474252100.jpg
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  36. #2675
    Westy's Avatar
    Dec 2008
    17,284
    Quote Originally Posted by Jason.s View Post
    Yeah that is a beauty, makes my paint job look sh!te
    S3 Build Thread
  37. #2676
    Westy's Avatar
    Dec 2008
    17,284
    Started painting the inlet mani yesterday:
    Hoping to have it refitted tonight after it's done an hour in the oven to cure. I've also ordered some green vac hose to dress the bay a little bit more.
    S3 Build Thread
  38. #2677
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Dont forget the strutt brace.....
  39. #2678
    Westy's Avatar
    Dec 2008
    17,284
    I'm still undecided on that mate. I'll see what things look like once the mani is back in.
    At least with the strut brace I can take it off the car for a week and still use the car. Which will give me more time to prep the strut for painting. I didn't have time to do a real good job on the mani so I hope it lasts.
    S3 Build Thread
  40. #2679
    Westy's Avatar
    Dec 2008
    17,284
    Into the oven with the mani:
    A much better finish then the rocker cover which wouldn't fit in the oven:
    Then all fitted back on the car:
    I've ordered some green vacuum hose to go with the theme. Need to tidy a few other bits like the charge pipe, dip stick, and washer bottle cap.
    S3 Build Thread
  41. #2680
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    what temp did you have the oven, and how long? lol
    i think it looks good. dont do the brace. just some vac hoses and a few other small ones would finish it nicely.
