View Poll Results: What colour S3 Avus for the Track?
Voters
63. You may not vote on this poll
  • Porsche Guards Red
    34 53.97%
  • Kawasaki Green
    29 46.03%
Page 59 of 90 FirstFirst ... 94952535455565758596061626364656669 ... LastLast
Results 2,321 to 2,360 of 3584
Like Tree124Likes
Thread: W3STY's Progress Thread
  1. #2321
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    and, i think the fact you are now over maxing the injectors by 26% is in a way awesome, and shows what can be achieved with the setup you've got. i think its fair to say you've accomplished your goal already.
    i just hope for you, and other people that follow this route that its reliable.
  3. #2322
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    Thanks guys that makes sense. Only thing to bear in mind is that will a 4 bar FPR give me enough of an increase through my injectors. I think uprating the FPR is the easiest way forward as like Bill mentioned, the ECU is used to a 386cc injector so If I start plopping in bigger injectors it might become a bit more messy.
    My fuel pump is brand new so should cope with the 4 bar FPR fine and if I need to I can always run an inline pump to compensate but that will be another couple of hundred squid.
    I'll go and do this log in a bit and see what Bill thinks. If a FPR will make much difference then I can get hold of one of those easily and it's a 5 min job to change.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  4. #2323
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Options to improve this are a 3.5 or 4bar fpr (so long as fuel pump is up to it and not old and tired)
    I'm not sure how the revo will accomodate the additional fixed fuel pressure, as on cruise and idle it will see increased fuel, and adapt it back out, but when on wot... this adapted out amount may still seem like its working as before and be of no help... Hmmm. Need to think what would be occuring. ECU is programmed to know it has an injector size of 386cc....
    ^keep what bill said in mind though, it might not be as simple as putting one in, well, it wont. so probably best you experiment with a fpr when you go and see him.
    Quote Originally Posted by Westy View Post
    it will be good for you (cheaper and easier) if the 4bar reg works. im guessing you want to avoid the cost of a custom map?? so injectors are kind of out of the question.
  5. #2324
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    I've got a 4 bar reg that won't be needed once I'm mapped and only done a few thousand miles, paid £45 for it but will sort something out if you want matey
    Only a 5min job to do as well
    Only downside is dont think will have it ready for as soon as you need it
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  6. #2325
    Westy's Avatar
    Dec 2008
    17,272
    Yes mate, trying to avoid custom map really as it wont be worth the cost. Would be nice to just have this running as quick and as stable as I can get it.
    Anyway here's the log data Bill requested. Did 3 runs:
    S3 Build Thread
  7. #2326
    RIP S3dave
    May 2004
    nr Glos
    7,153
    Can you explain to me how a 4 bar FPR will help? Will I not need larger injectors too as they are bein asked to work well beyond their means?
    more fuel pressure = more fuel for the same injector open time...
    4bar add's ~15% more fueling
    I see from the logs its already adding 10-20% fueling to achieve lambda..........
    afr on revo are richer than I set them on my custom maps... I never ask for 0.7x lambdas
    as an experiment worth getting hold of a 3.5 or 4bar fpr and dropping it in and see what the adaptions make of it.
    whats block 032 sat at currently?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  8. #2327
    Westy's Avatar
    Dec 2008
    17,272
    Ok cheers Bill I'll try and get hold of an FPR to test. I'll check block 032 later, what does that block show?
    From those logs am I ok to drive this car hard or should I be taking it easy?
    S3 Build Thread
  9. #2328
    Westy's Avatar
    Dec 2008
    17,272
    Ok, a brand new 4 bar FPR by itself is over £50 and it might not even do the trick. What do people think about an adjustable FRP like this one?:
    VW AUDI SEAT SKODA 1.8T TURBO ADJUSTABLE FUEL PRESSURE REGULATOR 3 - 5 BAR | eBay
    This would allow me to do a range of testing from 3-5 bar without having to buy multiple FPRs.
    S3 Build Thread
  10. #2329
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Block 32 shows what it has adapted to
  11. #2330
    Westy's Avatar
    Dec 2008
    17,272
    This is a value that changes as you drive isn't it? So I just need to read it, I don't need to do a run to get results?
    S3 Build Thread
  12. #2331
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yeah just read it, 2 sets of data idle and running
  13. #2332
    RIP S3dave
    May 2004
    nr Glos
    7,153
    actual fueling is ok.. 031..
    we now know that the ecu is using its adaption abilities to achieve this, and the injectors being max'd is part of this
    032 is fuel trims.. the learnt fueling adaption since last faultcode reset
    makes you wonder for all those who claim they already have 280bhp-300bhp+ on "some" rollers, will also be max'd on their duty cycles...
    bill@badger5.co.uk
  14. #2333
    Westy's Avatar
    Dec 2008
    17,272
    Oh bum! I've been resetting the engine fault codes every couple of days due to the EVAP system error I get now i've removed the charcoal can so the 032 figures might not be very helpful at the moment
    I'll drive it about a bit and wont reset the code if the CEL comes on just so we get some decent readings.
    S3 Build Thread
  15. #2334
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,543
    A custom map will fix all these issues you know... no more CEL from stuff you have removed and injectors/4bar dialled in correctly... plus tuned fully to take advantage of all the work you have done with the manifold/large port/wmi etc...
    <tuffty/>
  16. #2335
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,354
    Westicles, I've got a 4 bar fpr sat in the garage that you're welcome to try. Drop me a text with your address and I'll post it tomorrow or saturday
  17. #2336
    Westy's Avatar
    Dec 2008
    17,272
    <tuffty/>
    It's definitely something to consider it's just a shame this has reared its head just as i'm about to move house and car money will be dramatically reduced hence why I'm trying to make do with what I currently have.
    If I can get this setup to fuel ok and not run major high EGTs I'll be happy for the time being as it does feel quick through the gears.
    Found this info on the TT forum from Awesome about running the 4 bar FPR with revo stage2:
    Quote Originally Posted by AwesomeJohn
    It is fitted with a 3 bar FPR as standard.
    According to Revo a 4 bar FPR is a waste of money, the mapping is set to run with the standard FPR on the 210 and 225 cars.
    If you fit the 4 bar one it will over fuel the car by about 25%! The ECU with it's correction factors will correct this to about 12% still over fueling. Apparently this will not enhance your performance in any way.
    I do know quite a few people who tell me the car feels better with one fitted though!!!!!
    S3 Build Thread
  18. #2337
    Westy's Avatar
    Dec 2008
    17,272
    You sir are a legend. If you could get it in the post tomorrow I could do some logging over the weekend
    S3 Build Thread
  19. #2338
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,543
    Well... he is correct to a degree... just fitting a 4bar doesn't enhance the performance as such but... in your case it will provide a degree of fuelling headroom and the higher pressure does atomise the fuel better so this can lead to better idle and a better overall air/fuel mix...
    Obviously at the expense of extra strain on the std pump but yours is a new one so will be fine for the foreseeable future
    <tuffty/>
  20. #2339
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Bit off subject and sorry for spamming, but I'm now getting an eml for my evap which has been coded out? It seems to have started to occur after unplugging the resistor briefly, and reseting fault codes through vcds as well as a tb reset? Any ideas?
  21. #2340
    RIP S3dave
    May 2004
    nr Glos
    7,153
    it is likely a different resistance value.. a connection issue.
    n80 must bee seen... incorrect flow is what would have been coded out, although I dont remember doing this? (could be me.. memory of a goldfish and all that)
    bill@badger5.co.uk
  22. #2341
    Westy's Avatar
    Dec 2008
    17,272
    <tuffty/>
    4 bar is definitely the thing to try next then. I can always get an inline pump at some point in the future if needs be.
    More info I've found:
    Quote Originally Posted by VAGCHECK
    Just for clarity in regards occasional instances when we have deemed a 4bar FPR will be necessary for a particular modified 225 & its hardware (stock K04) if we are too >[/COLOR]
    1. Extract maximum safe performance
    2. Maintain well managed EGT’s
    3. Avoid totally maxing the injectors out
    4. Ensuring EGT protection management (fuel flood) is still possible. (Where applicable)
    In regards the 4bar FPR itself & the stock pump, yes it will be tasking the fuel pump more than with the stock 3bar reg that is a given, & we do normally convey this when discussing the options. If its not going to be needed for an individual vehicles tune then all well & good, as of course there is no good reason to place any component under more stress unnecessarily.
    The pump will cope with a 4bar reg + reasonable amount of boost providing it is healthy. Unfortunately as these vehicles get older in turn the pumps have also had a long life, & sometimes are already weak & sagging & in this instance fitting a 4bar reg would likely only expedite the pumps demise.
    Will it be needed with a stock K04 + full set of popular bolt on mods like intake, TIP, DP, cat/decat, cat back, FMIC etc, well this is dependant on how much air the turbo is able to push, how much boost is asked for by the tune at higher rpm’s, & the tuners desired AFR.
    We normally prior advise customers (in instances we think we might see a very high IDC) that we will review/log the vehicle with the stock fuel system before making the call on whether we are going to have to fit & calibrate for a 4bar to comfortably support our AFR targets.
    If it can be avoided then we do avoid it (less load on the pump, less cost for the customer etc)
    We are however also mindful to be sure the fuel pump is up to it in instances where a 4bar FPR is to be used, & measure/log fuel pressure if there are any doubts at all over the health of the pump.
    Ideally it would be a better overall solution to fit & calibrate for larger injectors when the stock injectors cannot flow enough with a 3bar reg, however costs are obviously quite a bit more with this route.
    Hope this helps.
    Regards
    Morgan
    S3 Build Thread
  23. #2342
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    OK, OK, no brown love please.
    Homer Simpson
  24. #2343
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    I did wonder if it was a connection issue as had pulled it out ( resistor has got little spade connectors soldered on there so could be inserted into oem plug ) to show tam and Westy a couple of weeks ago but have since checked it and all looks ok but now get eml for it?
    I've always got a the incorrect flow code but never got an eml from it and think may have jinxed it by telling / showing westy and tam the resistor and happily saying don't get any eml from it...doh
    Ps sorry for the hijack although slightly relates to one of your issues
  25. #2344
    Westy's Avatar
    Dec 2008
    17,272
    I'm finding a lot of contradicting info on 4 bar FPRs with Revo Stage2! It seems like the TT boys say it's awaste of time but the Skoda lads are saying it's needed. I even found info on Revo Stage2 products saying it is needed for stage 2:
    Revo Technik ECU Tuning Stage 2 Software for 1.8T Audi and Volkswagen Vehicles, Revo, Chip Tuning, Revo Technik Products & Other Performance Aftermarket Auto Parts - North American Motorsports
    Yet Revo's own website doesn't mention it as being "required":
    Revo | Audi
    I suppose it's all down to how the car is running.
    S3 Build Thread
  26. #2345
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,543
    Not sure why you are researching it mate tbh... facts are you have maxed your injectors... fitting a 4bar while running on your current map will give you a degree of headroom fuelling wise even if adaption will pull a bit out...
    If you want it right then its custom map time... you don't need to buy injectors as the 4bar will turn what you have into 440cc's effectively... the custom map will be scaled to suit and adaption won't be trying to pull all the fuel back out...
    <tuffty/>
  27. #2346
    Westy's Avatar
    Dec 2008
    17,272
    <tuffty/>
    I was only researching as I was wondering if Revo themselves recommend it or not, still not got a proper answer lol.
    Plan of action is this:
    Fit Prawn's 4 bar and see what the fuelling is doing in VCDS, if all is ok I will leave it as it is for the time being. I will then discuss with Bill availability and costs for a custom map at some point.
    I don't want Bill to spend a lot of time and me spend a lot of money on a custom map only for me to then need the same amount of time and money spent remapping it in the future for a BT.
    S3 Build Thread
  28. #2347
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,543
    Sounds like a plan...
    <tuffty/>
  29. #2348
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Pending what BT thinking of as for instance was going for gt28 and went for 550cc injectors on a custom map now then mapping won't be anywhere near as difficult when swapping to BT as been discussing a simular situ with bill at the mo about daves TT with future spec for upgrades as probably will go with a custom map with 550cc injectors with stage 2 spec hardware so costs are lower for hybrid ir other future spec?
    May be able to do something simular?
  30. #2349
    RIP S3dave
    May 2004
    nr Glos
    7,153
    Revo | Audi
    K03 cars needs it K04 cars dont - REVO
    end of
    thats the revo spiel
    Remeber... these are stage 2, generic remaps, and when revo did these, it was'nt on cars running higher flowing tips or manifolds.... so the goal posts have moved....... and this is where custom maps come into play
    If you plan on a BT at a later date... an option is custom map on larger injectors now, so when BT comes, if it comes, the injector scaling is already done, and you wont be paying full wack for another custom map..
    bill@badger5.co.uk
  31. #2350
    Westy's Avatar
    Dec 2008
    17,272
    Ok, so what size injectors will be the intermediate between my K04 and a possible GT BT in the future?
    EDIT- Just saw Stacey say 550cc, is this the recommendation then?
    S3 Build Thread
  32. #2351
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Think it'll depend on what size gt as there's a wide range of "big turbo" gt's
  33. #2352
    RIP S3dave
    May 2004
    nr Glos
    7,153
    need to be more specific on the turbo fella..
    620-870 ranges depending on flow of turbo chosen..
    bill@badger5.co.uk
  34. #2353
    Westy's Avatar
    Dec 2008
    17,272
    Quote Originally Posted by StaceyS3 View Post
    I've not thought that far ahead yet not to mention I have zero knowledge of BT setups!
    If I say 550cc injectors what would be the GT turbos I'd be limited to and what sort of power would I be looking at. I can relate to power
    S3 Build Thread
  35. #2354
    RIP S3dave
    May 2004
    nr Glos
    7,153
    I use 550's on k04 hybrids... and they run 85% IDC... for low 300s - thats a clue..
    620cc region.... ok for high 300's
    bill@badger5.co.uk
  36. #2355
    Westy's Avatar
    Dec 2008
    17,272
    Ok so ideally I'd want larger injectors because I'd want 400+bhp from a BT. What size injectors would you recommend for that and would it be possible to map those for a K04???
    S3 Build Thread
  37. #2356
    RIP S3dave
    May 2004
    nr Glos
    7,153
    620cc.... perhaps, and 4bar if you indeed did go for >400bhp
    should be mappable on k04 yes
    bill@badger5.co.uk
  38. #2357
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,354
    4 bar FPR in the post this morning Look forward to hearing how it works for you dude
    If it works, you can buy it :P
  39. #2358
    Westy's Avatar
    Dec 2008
    17,272
    Cheers mate. Hopefully it'll arrive tomorrow and I can do some logging this weekend.
    S3 Build Thread
  40. #2359
    Westy's Avatar
    Dec 2008
    17,272
    Just received prawns 4 bar FPR addressed to one "Fred the silver fox"
    Thanks for this mate. I'll get some logs done tomorrow
    S3 Build Thread
  41. #2360
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Good stuff Fred now that's service friends
    If your cruising about racking some miles up your more than welcome to pop to mine
