View Poll Results: What colour S3 Avus for the Track?
Voters
63. You may not vote on this poll
  • Porsche Guards Red
    34 53.97%
  • Kawasaki Green
    29 46.03%
Page 5 of 90 FirstFirst 1234567891011121555 ... LastLast
Results 161 to 200 of 3584
Like Tree124Likes
Thread: W3STY's Progress Thread
  1. #161
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    Just found a load of info so I'll give it a go.:
    This is a simple tuner application that can help fine tune your current setup. DISCLAIMER: This is not a full tune/map, just makes adjustments overall, not rpm increments. Since unisettings is up to date and works easier, here is the DL page Unitronic Chipped - UNI Setting V 1.4
    Channel Discriptions
    Ch01 : Idle Speed Offset
    Adjust idle RPM level
    - Higher number: increase idle rpm
    - Lower number: decrease idle rpm
    Ch02 : Fuel Tweak (Accel Pump); Increasing Loads
    -This channel adjusts a fuel enrichment under load
    -Modulates Throttle Response
    Ch03 : Fuel Tweak (Accel Pump); Decreasing Loads
    -This channel adjusts a fuel enrichment term coming off the gas or decelerating.
    Ch04 : Start Up Fuel Enrich
    Amount of fuel on any start ups?
    - Higher number: enrich the mix
    - Lower number: lean out the mix
    Ch05 : Warm Up fuel Enrich
    Amount of fuel on start ups E.G. on the first start in the morning?
    Ch06 : Lambda Regulation
    Controls how fast ECU adapts:
    - Higher number: faster adaptation
    - Lower number: slower adaptation
    Ch07 : Additive Offset To Speed Limiter
    Controls speed limiter in increments ok 1km/hr
    Ch08 : Secondary Fuel Tweak
    It adjust gain on the injectors responce
    - Higher number will increase the injector responce (smooths the ride)
    - Lower number will decrease injector responce (decrease backfires)
    Ch09 : Ignition Timing Offset
    Controls timing in steps of 0.75 degrees, all RPM range is altered
    - Higher number advances timing
    - Lower number retards timing
    Ch10 : Primary Fuel Tweak
    Controls fueling on run, ussually change multiplicative fuel trims
    - Higher number enrich the mix
    - Lower number lean out the mix
    Ch11 : Unused
    Unused
    Ch12 : SEL Scaling (Turbo Cars Only)
    Adjust fueling maps according to boost settings
    - Higher number increase injection period for higher boost
    - Lower number decrease injection period for lower boost
    Ch13 : OFF OFF
    Unused
    Ch14 : Idle Torque Additive Offset
    Controls engine load at idle
    - Higher numbers: spec load at idle is increased
    - Lower numbers: spec load at idle is decreased
    To use, you will need a vagcom cable (true Ross-tech.com prefered) and with the car on, hit the READ FROM ECU tap. This will bring up any changes made to the car previously and then you can make the changes you wish. When done, hit the WRITE TO ECU tap. This will be in the ecu until you change them again.
    Why do you need this? It allows you to do things like adjust idle to eliminate the noise from a fw or shaking from stiffer mounts. Adjust fueling on cold starts that can be an issue when using larger injectors to even curing backfires between shifts. The best part is with use of Vagcom, you can play with timing to get the most power out of your setup. With addition of race fuel, wmi (water/meth injection), or just a ic upgrade the iat (intake air temps) will be much lower allowing for more timing to be added resulting in more power. But keep in mind, like said before, these are overall adjustments and are far from a tune. You cant say screw a BT tune and add in 1000cc inj with a gt35r and expect to make it run well or at all.
    Found this info here:
    Unisettings/Lemmiwinks info page - AudiFreaks
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  3. #162
    S3 Paul's Avatar
    Oct 2006
    2,764
    I know a bit of a question you may not want to answer bill...
    But...
    Is this the kind of program you would use to fine tune a little more power from say my S3?
    I do agree this is best done by somebody with more than half an idea . I would gladly pay somebody like bill for his time to do this.
    Noggy Blue 2001 S3
  4. #163
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Get channel 3 cranked up for some nice pops/flames.....
  5. #164
    Westy's Avatar
    Dec 2008
    17,272
    Quote Originally Posted by S3 Paul View Post
    But...
    Bill used UniSettings or similar to change the timing/fueling on my Revo stage 1 just to fine tune it after the remap. It adjust some base settings on the Bosch ECU
    S3 Build Thread
  6. #165
    Westy's Avatar
    Dec 2008
    17,272
    lol, mentalist.
    S3 Build Thread
  7. #166
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I've been tempted myself to do just that for effect.... No cat to destroy here, so would be all good.... hehehe
    Homer Simpson
  8. #167
    S3 Paul's Avatar
    Oct 2006
    2,764
    Mine is on a custom code Stage 3 custom map.
    Its currently not max'd out . I just wondered if this is how they pulled the boost out as it used to hit 26 PSI but now sits at around 20 to 22
    Noggy Blue 2001 S3
  9. #168
    Westy's Avatar
    Dec 2008
    17,272
    Yeah it can be used to get a little extra out of a map by adjusting the timing/boost.
    S3 Build Thread
  10. #169
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,355
    I believe Bill does often make small changes using uni settings, I'm fairly sure that's how the extra timing is wound in when things like WMI are fitted, as it makes it very easy to pull said timing back out if anything fails.
  11. #170
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,355
    Ohps, I opened this page then replies 30 mins later, only to find a load of other replies had been made!
    fail.
    Can boost be turned above 100%? I'd imagine surely not, as otherwise people would be using it all the time to try and get more power!
  12. #171
    Westy's Avatar
    Dec 2008
    17,272
    fail.
    No it cant, I just tried clicking on the up arrow on the application and it stops at 100%
    S3 Build Thread
  13. #172
    S3 Paul's Avatar
    Oct 2006
    2,764
    100% of what though?
    The MAP'D figure or what the car/ turbo can manage?
    as my car did go wild and do about 2.5 bar when i first fitted new downpipe !
    Noggy Blue 2001 S3
  14. #173
    Westy's Avatar
    Dec 2008
    17,272
    Yeah it would be nice to know what the scale is between 0-100% regarding load scale, for example every 10% = 1psi. I dont really want to start playing around with it so i'll probably just run my car on actuator pressure until I see Bill next month. Unfortunately this will cock up all the VCDS testing I wanted to do with the B5 TIP and airbox/cone filter
    S3 Build Thread
  15. #174
    RIP S3dave
    May 2004
    nr Glos
    7,153
    Load Scale winds it all down... Its only allowed in this programme to scale down from 100%
    APR have their VTune which when on an enabled APR ecu allowed the load scale to be wound up above 100%
    it is DIY, but you can inflict damage if you get settings wrong.
    Be carefull is my advise.. logging is ESSENTIAL if you adjust things.. else you are blind to the results and likely consequences.
    I find unisettings more stable than lemmiwinks
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  16. #175
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,355
    Quote Originally Posted by Westle View Post
    Dude, you're turning the boost DOWN,
    For reference, and to give you an idea, a mate of mine had a P-torque mapped 225 LCR, which on the liquid guage, showed about 260bhp when run at 100%, he turned it down to 70% on the load scale in unisettings and it drove like a standard car, and logged 210-215bhp on the liquid.
    If you've got a boost guage, whack it down to 80% load and see what you get, if it drops you to like 15psi, whack it back up 5% at a time until you're around 20ish, THEN fit your B5 TIP and do some comparison testing!
  17. #176
    Westy's Avatar
    Dec 2008
    17,272
    I like the plan Nick thanks.
    I know i'm turning boost down, I'm just very careful about what I do after just spending £1700
    I could do with getting the boost down to around 20/21psi so it's inline with the old turbo but if I lower the load scale have I got to adjust anything else?
    S3 Build Thread
  18. #177
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Agreed ^^ you can always put it back to how it was
  19. #178
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,355
    No, just turn the load scale down and that's it.
    my mate had a mental LCR, 3'' DP/decat, massive FMIC WMI, running 8.25 degrees of additional timing through uni settings flowing 236g/s on a stock ko4!
    When he sold the car, he removed ALL the mods so it was standard but still with the map on, and turned the load scale down to 70% in uni settings and sold it as a standard car
  20. #179
    Westy's Avatar
    Dec 2008
    17,272
    Haha cheeky sod.
    Ok I'll turn it down when I get home and get some logs done. S3 Baby is on his way back from Revo HQ to help me do my rear tie bars. He's got a stage 2 map and his clutch has already started to slip on the way home lol
    S3 Build Thread
  21. #180
    Westy's Avatar
    Dec 2008
    17,272
    Guys, I cant get UniSettings to connect to the ECU:
    Any ideas?
    S3 Build Thread
  22. #181
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,355
    Perhaps Jesus hates you?
  23. #182
    RIP S3dave
    May 2004
    nr Glos
    7,153
    your car sux - comms issues dude
    same as when I "eventually" flashed it
    got any ICE installed which could mess with the k-line?
    On mk3 ibiza's which do this often I pull the inst cluster fuse and comms works for them
    bill@badger5.co.uk
  24. #183
    Westy's Avatar
    Dec 2008
    17,272
    I don't believe in him but he might do! Looks like I'll just pull the N75 to be on the safe side, scrap my logging and just fit the TIP.
    dusty likes this.
    S3 Build Thread
  25. #184
    Westy's Avatar
    Dec 2008
    17,272
    Ah yes I remember you killing all the interior lights when I was at yours. I'll give that a go.
    I don't have anything fancy ICE wise just a xcar link phone kit!
    S3 Build Thread
  26. #185
    Westy's Avatar
    Dec 2008
    17,272
    Ok I pulled the fuse for the interior lights and the instrument cluster and it still wont read the ECU. S3 Baby popped round and it wont work on his either.
    What version of UniSettings are you lot using?
    S3 Build Thread
  27. #186
    Westy's Avatar
    Dec 2008
    17,272
    I just found this little guide on another forum so i'll give it a try tomorrow morning:
    The RossTech USB cable won't communicate with Unisettings if you have "intelligent mode" check under the Options menu. Usually you will see an error like "Unable to initialize communication"
    So what you have to do?
    1. Turn car just to ON (not full start)
    2. Connect Vag cable to RossTech software and look for Options
    3. Uncheck the "intelligent mode", hit Test, then Save.
    4. Cycle the car OFF (wait a second) and then turn ON again
    5. I have better results with RossTech software close and open Unisettings
    6. Try reading from the ECU
    S3 Build Thread
  28. #187
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Ive tried it and have the same problem, are you using vista?
    Works with APRs vtune ok, but im APR tuned so not sure if vtune will work on yours?, very similar options
  29. #188
    Westy's Avatar
    Dec 2008
    17,272
    I'm using windows 7 but I do now have it installed on a laptop with xp as I thought that might be an issue. I'll try again later today
    S3 Build Thread
  30. #189
    Westy's Avatar
    Dec 2008
    17,272
    I drove into work this morning with the N75 disconnected and only boosting to 6psi actuator pressure. So it must just be my fresh turbo producing 25psi with the N75 connected!
    S3 Build Thread
  31. #190
    RIP S3dave
    May 2004
    nr Glos
    7,153
    mines win7 on unisettings and works fine.
    bill@badger5.co.uk
  32. #191
    RIP S3dave
    May 2004
    nr Glos
    7,153
    ahh yes.. Good point, forgot that bit.
    check in your vag-com settings menu its no in intelligent mode.. if so untick the box and save, then quit and try uni again.
    bill@badger5.co.uk
  33. #192
    Westy's Avatar
    Dec 2008
    17,272
    Ok I'll try disabling "intelligent mode" in VCDS as discussed above. I'll try it on my lunch break and let you know.
    S3 Build Thread
  34. #193
    Westy's Avatar
    Dec 2008
    17,272
    It worked
    I disabled "intelligent mode" and it worked first time. I've wound it down to 85% and I'll take for a spin later to see what boost I now have.
    S3 Build Thread
  35. #194
    RIP S3dave
    May 2004
    nr Glos
    7,153
    sweet - result
    bill@badger5.co.uk
  36. #195
    Westy's Avatar
    Dec 2008
    17,272
    Just been out for a blast and some logging.
    Boost is doing weird things. Had to up the load to 95% to get 20-21psi in 3/4th gears but in 5th & 6th it still wants to boost to 25-26psi!!!
    Anyway did a quick log in 4th gear but couldn't get it right to the redline due to traffic conditions. Registered 207g/s (roughly 258bhp) and didn't see timing pulled more than 4.5 degrees.
    If I can take it to the redline i'm sure of a few more g/s
    If I get anything like Dane's gains from fitting my B5 TIP I'll be knocking on the door of 280bhp!
    S3 Build Thread
  37. #196
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,355
    Sounds good man, 207g/s from a revo stage 1 with the load turned down is good going! get Bills TIP on there and it's going to fly!
  38. #197
    Westy's Avatar
    Dec 2008
    17,272
    I know, I was surprised myself. I'll be seeing Bill on the 1st of July to get the issue bottomed out so should be a great motor for the Ring trip
    S3 Build Thread
  39. #198
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Yeah man, agreed, good going!!
    Homer Simpson
  40. #199
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,355
    I know, I was surprised myself. I'll be seeing Bill on the 1st of July to get the revo stage 2 loaded on so should be a great motor for the Ring trip
    You'll need an FMIC fitted asap then!
  41. #200
    Westy's Avatar
    Dec 2008
    17,272
    It'll be on order monday then fitted as soon as it arrive in one of my famous late night mechanics sessions
    S3 Build Thread
