EM TuningVolks Autos
View Poll Results: What colour S3 Avus for the Track?
Voters
63. You may not vote on this poll
  • Porsche Guards Red
    34 53.97%
  • Kawasaki Green
    29 46.03%
Page 49 of 90 FirstFirst ... 3942434445464748495051525354555659 ... LastLast
Results 1,921 to 1,960 of 3584
Like Tree124Likes
Thread: W3STY's Progress Thread
  1. #1921
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Quote Originally Posted by ;1509760
    Oh yeah... and make sure you cover the crank journals so the crud doesn't get on them and watch the oil squirters!!!
    <tuffty/>
    What's the best way to protect the crank from any of the crap dropping down onto it?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  3. #1922
    RIP S3dave
    May 2004
    nr Glos
    7,167
    <tuffty/>
    be very carefull doing honing remembering oil squirters are easily clobbered and bent.. AND also when you drop the rods in, make very sure they also dont clobber the squirters... very easy to clip them and bend them backwards with the rod.
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  4. #1923
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Quote Originally Posted by Westy View Post
    Rags and shizzle
    <tuffty/>
  5. #1924
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by ;1509835
    Rags and shizzle
    <tuffty/>
    Real technical yeah
    S3 Build Thread
  6. #1925
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Real technical yeah
    Pretty much
    <tuffty/>
  7. #1926
    Westy's Avatar
    Dec 2008
    17,273
    I've been doing some reading on bore honing and surface prep and there seems to be mixed opinions. Some people say "leave it to the professionals" and some people say "DIY".
    Apparently its easy to get it wrong if you hone at the wrong angle or at the wrong RPM. Bear in mind that I'll be doing it with the block in situ (decided to leave it in now) so would need to get the hone brush dead straight over the top of each bore to get it just right.
    I assume that just banging in fresh rings without honing/prepping each bore is a big no no?
    S3 Build Thread
  8. #1927
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Its not that much of a black art... you do need to take the usual precuations but there are plenty of videos on youtube (including the ones in my build thread I linked too)
    There needs to be a cross hatch pattern that helps 'machine' the rings to the bore.... don't fit rings if you are not honing
    <tuffty/>
  9. #1928
    Westy's Avatar
    Dec 2008
    17,273
    <tuffty/>
    My main worry is that I could fit new rings and hone but still end up with problems due to me doing it wrong. Then again I could refit the worn rings and end up with problems at a later date too
    S3 Build Thread
  10. #1929
    RIP S3dave
    May 2004
    nr Glos
    7,167
    Given your cars performance is pretty good.... I doubt there's much wrong with your rings..
    I would be temped to leave them and the bores alone. Clean the piston crowns and reinstall
    unless you see nasty scoring when you take it apart it will be ok more than likely
    you risk more than you are likely to "improve"
    www.badger5.biz
    bill@badger5.co.uk
  11. #1930
    Westy's Avatar
    Dec 2008
    17,273
    Thanks Bill. That's exactly what i'm worried about! I could do more harm by fitting new rings. I'll assess the rings and bores once it's apart.
    S3 Build Thread
  12. #1931
    Reesy's Avatar
    East Sussex
    3,604
    Thanks Bill. That's exactly what i'm worried about! I could do more harm by fitting new rings. I'll access the rings and bores once it's apart.
    Access or assess?
  13. #1932
    Westy's Avatar
    Dec 2008
    17,273
    Little bit of progress tonight. Firstly I wanted to line up the XS mani with the head to see what I'm working with getting the nuts onto the studs. It's tighter then a gnats a-hole! I'm going to do what Prawn did and get a 12mm ring spanner and cut enough out of it so I can get it over the nuts.
    Here's some pics of how tight it is:
    After knowing what i'd be dealing with when getting round to the mani I decided to start painting my spare BAM rocker cover in "Kermit Green"
    It's coming along nicely. Going to leave it for a week now to dry before applying another 3 coats. I also need to bake it in the oven for an hour at 100C to cure it!
    Last job of the night was to make my phenolic gasket into a transition gasket so that there's a smooth transition between the small port inlet manifold and the larg port head:
    Small Port side:
    Large port side:
    And with the large port gasket over the top you can see I still need to tidy up the edges a bit:
    S3 Build Thread
  14. #1933
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    I hear you in the tight fit experience. Mine was a ***** to fit.
    I just to give you a heads up for your clutch install too. Was speaking to my Mechanic today and he mentioned how little space there is to work on the car with all of the uprated parts like arbs, Downpipe, mani, turbo etc...to physically access get to the clutch and flywheel. He said it delayed him a couple of hours over standard set up. You may experience the same.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
  15. #1934
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Nice progress, hair dryer works a treat for hi gloss....
  16. #1935
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    Try putting the mani in the oven for fifteen mins it might make it a lil bit more willing to play ball and make it a wee bit easier
  17. #1936
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Dane View Post
    What do you mean mate? Surely all that will happen is I'll end up with a hot manifold that's now even more difficult to get a nut onto an already tight stud?!
    S3 Build Thread
  18. #1937
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Will expand very marginally, usually heat external bearings sleeves if they're an interference fit as can make it expand enough to slide on a shaft then shrinks back tight as it cools, may be enough if you've got one stud that doesn't quite line up with a hole but would usually only expand couple of hundreths of a mm
    It's looking good mate all prep for it's Easter treat
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  19. #1938
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by StaceyS3 View Post
    There's no problem with fitment at all, it goes over all studs like a glove. Just not looking forward to getting cramp trying to tighten the nuts for those difficult studs
    Prep wise I'm now there. Just need to wet and dry the phenolic gasket so it's spot on and give the rocker cover another few coats of paint.
    I've now got all the parts I need except the 2 most important, the rods and the clutch!
    S3 Build Thread
  20. #1939
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,457
    You re making fantastic progress now westy. Im loving the Kermit green mani. When are you getting the clutch and the rods? Will you have them on time for the easter build? Keep up the good work westy.
  21. #1940
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Sandra View Post
    Rods should be within the next week or two. Backdraft are chasing IE up. The clutch kit is coming from Awesome and even though they said that the parts are out of stock, they told me that they can get them in within 2 days. So far it's been a week!
    Still got 4 weeks till the build so I should have everything in time. I bought everything nice and early just incase I encountered any delays like this.
    S3 Build Thread
  22. #1941
    Westy's Avatar
    Dec 2008
    17,273
    My parcel from awesome turned up today.
    1 slave cylinder/release bearing:
    1 black coolant bottle cap:
    1 clutch plate:
    And 1 pressure plate:
    Just waiting in the rods from IE now which are due to be dispatched from the states in the next few days so should have them by next week.
    S3 Build Thread
  23. #1942
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Have you/are you fitting a single mass flywheel mate? like you and my thread I can't keep up with yours either lol ;P
    <tuffty/>
  24. #1943
    Westy's Avatar
    Dec 2008
    17,273
    Whoops, I missed the flywheel.
    SMF weighted to give the same pedal feel as a double apparently:
    S3 Build Thread
  25. #1944
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Phew! :D
    <tuffty/>
  26. #1945
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by ;1521845
    Phew! :D
    <tuffty/>
    I started making dinner and I was thinking to myself that box was rather heavy considering there wasn't much in it. Then the penny dropped
    S3 Build Thread
  27. #1946
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    What clutch is that? It better not be one of them red crap techniclutches!!
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  28. #1947
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Andrew@A.L.D View Post
    Haha no mate I wa warned to steer clear of those, maybe by yourself. This is Awesome GTIs clutch kit which they have apparently been testing for a while and run on one of their cars puttin out over 400lbft torque.
    Nobody had tried it on their S3 so I thought I'd be the ginnea pig
    S3 Build Thread
  29. #1948
    Jun 2009
    Leeds
    3,469
    Thank god
    Was the testing done in a FWD of 4WD car?
    FOR SALE
  30. #1949
    Westy's Avatar
    Dec 2008
    17,273
    Thank god
    It doesn't say. Take a look here:
    http://www.awesome-gti.co.uk/product...7051&xSec=9418
    S3 Build Thread
  31. #1950
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    The birth of the Freddo clutch.....
  32. #1951
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Any idea what the weight of the smf is compared to the dmf westy?
  33. #1952
    Westy's Avatar
    Dec 2008
    17,273
    I'm guessing this one will be similar to the duel mass as it's weighted so it feels the same but I'll weight them both for you if you like?
    S3 Build Thread
  34. #1953
    May 2010
    Bedford
    2,877
    Same as the diesel flys we use on the a4s. Wish I had it lightened though
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  35. #1954
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Jason.s View Post
    Thing is, I've had harsh clutches on other cars in the past and it doesn't bother me for the short trips I normally do. I'm not fussed about messing withthis flywheel I'll just fit it all as it is.
    S3 Build Thread
  36. #1955
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Yeah if you can please mate.
  37. #1956
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    So Westy's SMF is an actual VAG part?
    <tuffty/>
  38. #1957
    May 2010
    Bedford
    2,877
    Nah i just mean the diesel SMF we use on the A4`s are the same weight as the DMF sadly. No idea what fly the Awesome kit uses.
  39. #1958
    Westy's Avatar
    Dec 2008
    17,273
    I wouldn't be surprised if it was a sodding VAG part from another model.
    S3 Build Thread
  40. #1959
    Westy's Avatar
    Dec 2008
    17,273
    I thought I'd grab a few rocker cover shots with the R8 cap on it (just for Sportstractor) before I put the last coats of paint on it. Just needs to be cured in the oven now then a coat of lacquer to finish it off.
    S3 Build Thread
  41. #1960
    Chugger
    North Devon
    2,716
    Nice, won't look so great when covered in oily finger prints though.
    Also just seen on Facebook. Rtech have managed to get a ko4 to 304bhp... On their rollers anyway... But you will easily smash that with your r8 cap
    57 A3 2.0 TDI Sportback (140)
