Volks AutosJMB Retrofits
View Poll Results: What colour S3 Avus for the Track?
Voters
63. You may not vote on this poll
  • Porsche Guards Red
    34 53.97%
  • Kawasaki Green
    29 46.03%
Page 19 of 90 FirstFirst ... 91213141516171819202122232425262969 ... LastLast
Results 721 to 760 of 3584
Like Tree124Likes
Thread: W3STY's Progress Thread
  1. #721
    RIP S3dave
    May 2004
    nr Glos
    7,183
    Quote Originally Posted by S3Lol View Post
    this came from Tufftys thread...
    If you don't mind loosing fogs and having pipes on show then fit an ebay cooler like Welly has... no apparent flow restriction and repeatable results on the dyno... if you want to retain the fogs then essentially do a ****e load of work like S3 Paul did to get an ebay one in, fit and AH/Forge with 51mm outlets or wait and see 'if' I can get 60mm outlets onto the AH in which case you could have a chat with Alex about producing something similar...
    Alex says the core is good for 400+bhp which will be where I am aiming for but thats not to say it wouldn't benefit being larger or deeper...
    As I have said in the FMIC thread I started its really down to how much work you are prepared to put in to get something like this fitted and how much compromise you are willing to make as to what has to go...
    For a K04 (std or hybrid) then I don't see it being a major problem as tbh they run on the edge when you try to get the most power from them... all the S3's dyno'd so far are very sensative to heat and they produce a lot of it when maxed... there isn't much a larger FMIC will do to help there, WMI is what you want for that...
    My engine produces the same power on 1.5bar as it was at nearly 2bar but the difference is it runs cooler... this suggests that despite the turbo being able to produce the the airflow for more power, the components of the engine will not flow it... this backs up and produces more heat which pulls timing yadda yadda yadda....
    To answer your question, going 60mm will remove the current bottle neck 'I' am experiencing with the FMIC, on a K04 you would not really notice it... but I will need to do the same (improve overall flow) on the rest of the engine components before I can turn up the boost a bit more and realise the potential left in my GT30... larger throttle body, large port head and eventually a large port SEM inlet mani will give the the full flow potential of the turbo and whack my power up a bit to boot...
    < tuffty/>
    and look at post #193 in the bit below. I based my purchase on this information.
    http://www.audi-sport.net/vb/a3-s3-f...tml#post872642
    and if you read ALL of the thread you will see, what it actually performed like with DATA confirming its shyte.
    On face value this cores been claimed to be many things by Alex.. Facts and Data however, say to the contrary... Words vs Data
    On bog stock k04 on a stage 1, it cooled more than twin smic.. after that, its inadequacies became more and more apparent. Pipesize is too small, and the core itself does not support the GT30 that paul runs.. It was a k04 install to begin with. Pipes were enlarged (by me) and made no noticable difference.. Only when logging pre-post intercooler on the dyno, did the issue reveal istelf, and reveal the sales patter to be very inaccurate.
    Avoid it.. and dont believe the AH info... its not supported by test data
    There is no surprise, that now knowing the data, a larger fmic was embarked upon, which was based on a core used on rs500... trimmed a little to fit an S3, and this is what should be offered imho to S3's, REPLACING the smaller, proven to be inadequate, unit. The only people to have tested it are us... as far as I am aware. The info is posted on this forum in tufftys very open/honest build thread, for others to see.
    My advise is forget the smaller core..
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  3. #722
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,374
    Hmmmmmmmmmmm, this thread is making me think.....
    I've got 51mm piping on my hot side, and 63mm on the cold side, with 63mm inlets and a small core like Westys.
    I was planning to simply drop in the large toyosports core for my hybrid, with reducers on the ends to my 51 and 63mm pipes.
    Is the 51mm hotside piping from the turbo to the IC going to cause a problem? or should that be big enough to support the 300bhp I'm chasing?
  4. #723
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    < tuffty/>
    A lot of water has passed under the bridge I guess since then...
    Based on further findings I can say that even with the 60mm ends I put on mine I was still experiencing issues with pressure drop...
    Guess I could do with adding an update to that but all I can really say is that the original FMIC from AH on 51mm ends made a noticable improvement when I fitted it. Since going big turbo I have gone through several changes and tests etc as I 'develop' my build... this has come to highlight that the core of the original AH Fabs just isn't up to the task of supporting my configuaration and arguably anything beyond a stage 2 K04 it would seem...
    I should update that thread really if peoaple are basing buying decisions based on info that is now out of date...
    <tuffty/>
  5. #724
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I have read that making a larger cold side can reduce pressure drops....
  6. #725
    RIP S3dave
    May 2004
    nr Glos
    7,183
    stock 225bhp piping is 60mm............
    why make it harder for the turbo to pump air thru?
    www.badger5.biz
    bill@badger5.co.uk
  7. #726
    RIP S3dave
    May 2004
    nr Glos
    7,183
    <tuffty/>
    and peeps they should'nt make conclusions before reading the whole thing,.. They need to read the whole thing to understand the evolution......... if they have a handy day to read it - lol
    www.badger5.biz
    bill@badger5.co.uk
  8. #727
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by W3STY View Post
    Right guys, I think you've made up my mind for me. Bye bye fog lights
    Homer Simpson
  9. #728
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,374
    Mines a 150bhp ko3 car though Bill, and the IC kit is designed with that in mind, so the hot side pipes are 51mm just like the turbo outlet.
    I'm just trying to work out if I'll need to completely redo my FMIC setup, or if I can drop a larger core into my existing pipework.
  10. #729
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,281
    Ill be using 2 76mm - 63mm reducer 90 degree silicone bends on the core. This means I can keep all the 63mm hosing i've already bought
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  11. #730
    Westy's Avatar
    Dec 2008
    17,281
    S3 Build Thread
  12. #731
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,787
    mr silicone must love you
    and mrs silicone probably spends all his profits
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  13. #732
    Westy's Avatar
    Dec 2008
    17,281
    Quote Originally Posted by Sam_ View Post
    lol. I could be a Mr Silicone distributor with the amount of stuff i've bought off him recently!
    S3 Build Thread
  14. #733
    RIP S3dave
    May 2004
    nr Glos
    7,183
    you have changed your requirements......... so what worked before wont be as well suited to the 300bhp goal you now plan for.
    www.badger5.biz
    bill@badger5.co.uk
  15. #734
    Westy's Avatar
    Dec 2008
    17,281
    Prawny, just get jiggy with Mr biggie
    S3 Build Thread
  16. #735
    Jul 2009
    Cambridgeshire, United Kingdom
    427
    Which intercooler would you recommend with the max I will be going is a K04 hybrid (See my sig for other supporting mods).
    Current
    Porsche Cayman S
    Gone but not forgotten
    Audi S3:Blueflame TBE; 3" blueflame downpipe; Forge 007p; jabbasport custom map; Badger 5 TIP v1, various bushes, N249 Bypass, Stack Boost Gauge, Junior GT Brembo brakes, tarox 2 part discs, DS2500's
  17. #736
    RIP S3dave
    May 2004
    nr Glos
    7,183
    check out Danes thread... just updated it
    crossposted to here..
    anyhows...
    look what turned up from Toyosports
    existing bumper bar trim clears well
    alignment to existing ends..
    Makes it look a lot better than this
    Original sized AH thing
    The modded ends on the AH V1 thing, from 51mm to 60mm 90' bend inlets
    vs Tufftys (larger) core, which should be the V2 AH item I am 'not patiently waiting for'
    and fogs remain fitable on tufftys.. (not likely on 76mm ends of the toyo tho)
    www.badger5.biz
    bill@badger5.co.uk
  18. #737
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    That's a bargain, why pay 600 for a porge fmic?
  19. #738
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    when you can just spray forge on it lmao my fmic went from £200 to £600 in 5mins lol
  20. #739
    Westy's Avatar
    Dec 2008
    17,281
    Well, Tuesday night is late night mechanics night so in true fashion Tam and I attacked a few jobs.
    First up was to replace my poor old tired intank fuel pump. My visit to Bill's two weeks ago revealed that my fuel pump just couldn't pump enough fuel high up the rev range. He believes this to be down to the pump having to work over time on my last map as it was constantly triggering the EGT protection and dumping fuel in to cool the engine down.
    Back seats out and service panel off:
    Fuel clips and electrical clip off:
    Top of pump off:
    Whole pump out. Staring into half a tank of V power
    Was starting to get a headache from the petrol fumes at this point but cracked on.
    Lovely new clean pump:
    Bottom part in:
    All done:
    I started her up and she was fine so cracked on with the next job.
    As a birthday present Tam had nocked me up one of his tasty heat shields for my Jetex, he's a good lad
    We plonked it in to see what was needed. I'd cut my top 90 degree bend for my B5 TIP as I fitted it to my airbox so I'll need a new top piece now.
    All of this was done by 9pm and we were a bit lost for things to do so I wrapped my grill surround. It took an hour and a half and i'm not 100% happy with it but its better than the stone chipped ming blue it was before:
    I'll get a pic with it on in the day light tomorrow morning.
    Late night mechanics is soon to become a thing of a past as I'm nearly done. Just need to fit my Boxster Brembos and fit my new FMIC and i'm finished.
    Look out for some late night detailing coming soon
    S3 Build Thread
  21. #740
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    It's nearly the end of whats been a great series
    Good work.
    So when will you be getting the map updated, surely there's a little more to be had out of the old girl?
  22. #741
    Westy's Avatar
    Dec 2008
    17,281
    Good work.
    With the new fuel pump and the FMIC there should be a bit more to squeeze out the minger. Not sure when I'll get back to bills again but it'll happen eventually.
    S3 Build Thread
  23. #742
    Westy's Avatar
    Dec 2008
    17,281
    And here's the newly wrapped grill surround on, in the light:
    S3 Build Thread
  24. #743
    May 2010
    Bedford
    2,877
    Glad the pump went well :D Was dreading coming on this morning to find a PM saying the pump was wrong or something lol.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  25. #744
    Westy's Avatar
    Dec 2008
    17,281
    Quote Originally Posted by Jason.s View Post
    Thanks again Jason.
    It was spot on, I did check the part number before removing the old pump
    S3 Build Thread
  26. #745
    May 2010
    Bedford
    2,877
    haha no worries. I knew it was right but if it was a customer over the front tbh i wouldnt be that bothered if it was wrong lol. Someone on here caused me to panic a bit
  27. #746
    Westy's Avatar
    Dec 2008
    17,281
    Just popped home for lunch and had possibly the best post ever waiting for me
    Firstly was my AITP ticket
    Secondly was my paperwork from the DVLA allowing me to fit these:
    Then there was my huuuuuuge FMIC core and the pipework to do it. Roll on this evening
    S3 Build Thread
  28. #747
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Pimping! !!
  29. #748
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Pics of when I was offering up the Welly'esque FMIC on mine...
    <tuffty/>
  30. #749
    Westy's Avatar
    Dec 2008
    17,281
    Thanks Tufts. Someone went a bit OTT on the crash bar didn't they?
    Any pics of how it was fixed in place?
    I just couldn't believe how big the in/out was, could nearly fit my fist in!
    S3 Build Thread
  31. #750
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Looking at that pic of the toyosports fmic, surely you could fit 2 reducing elbows (1 either side) so the pipework went into the smic area, that way would you then be able to keep the fogs?
  32. #751
    Westy's Avatar
    Dec 2008
    17,281
    That's the plan batman I'll let you know how it goes in a few hours.
    S3 Build Thread
  33. #752
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Never fitted it in the end so no not got any pics for that... was too big for keeping fogs
    Its plausible that knowing who and what I know now that I could have changed the ends and welded on 63mm pipes etc to allow it to stand a chance of fitting I guess... not sure what the actual size comparison would be but...
    ...vs my new AH one...
    The ebay one being deeper of course... its possible it could be made to fit like my AH one with a bit of tactical fabrication...
    <tuffty/>
  34. #753
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    That looks exactly the same as mine!
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
  35. #754
    Westy's Avatar
    Dec 2008
    17,281
    They do look similar width wise. I suppose if you know someone whos handy at welding it could be done. I'll see what the deal is with the reducers on.
    S3 Build Thread
  36. #755
    Westy's Avatar
    Dec 2008
    17,281
    Quote Originally Posted by s3 Hoggy View Post
    Well we cant help having style Hoggy
    S3 Build Thread
  37. #756
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Hahaha
    2002 S3 REVO
  38. #757
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    My thoughts too
  39. #758
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    regarding fogs, saw a thread on here about having the cool upside down to save fogs....?
  40. #759
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    If the inlets..outlets are bigger than 65mm you lose the fogs.....theres just not enough room even if you reduce them down to 63mm
  41. #760
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    I have 63mm bends and they fit but... if you are just using ends and silicon joiners the joiners will be too large...
    Looking at the ebay one I reckon you could cut off the 76mm outlets, weld a couple of 63mm 90's on (need to be right at the bottom) then infill the hole thats left... that could work... it looks fairly similar in size otherwise...
    <tuffty/>
