JMB RetrofitsBadger5
View Poll Results: What colour S3 Avus for the Track?
Voters
63. You may not vote on this poll
  • Porsche Guards Red
    34 53.97%
  • Kawasaki Green
    29 46.03%
Page 13 of 90 FirstFirst ... 3678910111213141516171819202363 ... LastLast
Results 481 to 520 of 3584
Like Tree124Likes
Thread: W3STY's Progress Thread
  1. #481
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Your turbos still spiking.....is it still set low from unisettings?
    Im Not sure what to say about them logs...mine drops on boost not off boost...lol, as soon as the turbo spools the temps drop very quickly
    Nice Air flow, for a stage 1 you cant argue with that....
  3. #482
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by W3STY View Post
    This whole setup was about £200 all in. Cutting the bumper is a pain in the arse but 99% of fmic installs need a little bit of trimming. I think that if the core had smaller ins/outs between 50-55mm it would have been a lot easier to get the bumper and trim on. I only used 63mm because the standard smics use 63mm.
    You even have to trim when you buy the 2nd mortgage forge IC
  4. #483
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    What wer your temps before mate? How does it feel to drive, can you tell any difference?
    Temps were a good 5 degrees higher before and the heat of the inlet mani after a run was quite noticeable. I only did a quick 20 min blast but the car does feel stronger.
    yeah load in uni settings is down at 90% to stop the turbo hitting 25psi it's holding around 17-19psi at the mo! Should get that all sorted at Bills next Friday.
    The max heat in my log was at redline then it drops right back down to 24 degrees as soon as the heat pump is off boost. I don't know if that's right or not but my log before with the smic I was seeing nearly 40 degrees on full chat.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  5. #484
    Westy's Avatar
    Dec 2008
    17,283
    I've looked through the following list and I think I can set the AC screen to show AITs so I can check them without having the laptop constantly plugged it:
    Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
    NOTE: Air Flow Motor (V 71) and Potentiometer (G 113) are not installed in USA/Canada vehicles. Disregard values displayed for these components.
    Code Displayed Value
    1 System malfunction - displayed as a Diagnostic Trouble Code (DTC), see chart below
    2 Digital value of Interior Temperature Sensor, in Headliner (G 86)
    3 Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
    4 Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
    5 Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
    6 Digital value of Outside Air (Ambient) Temperature Sensor
    7 Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
    8 Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
    9 Delta value of Temperature Regulator Flap
    10 Non-corrected specified value of Temperature Regulator Flap
    11 Digital value of Central Flap Motor Potentiometer (G 112)
    12 Specified value of Central Flap
    13 Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
    14 Specified value of Footwell/Defroster Flap
    15 Digital value of Air Flow Flap Motor Potentiometer (G 113)
    16 Specified value of Air Flow Flap
    17 Vehicle Speed (km/h)
    18 Actual Air Blower voltage (Volts)
    19 Specified Fresh Air Blower voltage (Volts)
    20 A/C Compressor (A/C Clutch) voltage (Volts)
    21 Number of low voltage occurrences, non-transient
    22 Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
    23 Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
    24 Cyclings of the switches, absolute non-fluctuating
    25 Analog/Digital value, Kick-Down Switch
    26 Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
    27 Coding value
    28 Engine Speed (RPM)
    29 A/C Compressor speed in rpm (Equals Engine Speed x 1.28)
    30 Software version
    31 Display check (all segments of A/C Control Head display light up)
    32 Potentiometer malfunction counter, Temperature Regulator Flap
    33 Potentiometer malfunction counter, Central Flap
    34 Potentiometer malfunction counter, Footwell/Defroster Flap
    35 Potentiometer malfunction counter, Air Flow Map
    36 Feedback value, cold end-stop, Temperature Regulator Flap Motor Potentiometer (G 92)
    37 Feedback value, hot end-stop, Temperature Regulator Flap Motor Potentiometer (G 92), max. stop
    38 Feedback value, cold end-stop, Central Flap Motor Potentiometer (G 112)
    39 Feedback value, hot end-stop, Central Flap Motor Potentiometer (G 112)
    40 Feedback value, cold end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
    41 Feedback value, hot end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
    42 Feedback value, cold end-stop, Air Flow Map Motor Potentiometer (G 113)
    43 Feedback value, hot end-stop, Air Flow Map Motor Potentiometer (G 113)
    44 Vehicle operation cycle counter
    45 Calculated interior temperature (internal software, in digits)
    46 Outside (ambient) temperature, filtered, for regulation (internal software)
    47 Outside (ambient) temperature, unfiltered, (internal software, in deg C)
    48 Outside (ambient) temperature, unfiltered, (in digits)
    49 Malfunction counter for speedometer (vehicle speed) signal
    50 Standing time (in minutes)
    51 Engine Coolant Temperature (ECT) in deg C
    52 Graphics channel 1 - A/C compressor switch-off conditions are identified by illuminated segments of the �88.8� display. See chart below.
    53 Graphics channel 2 - Climate system electrical outputs are identified by illuminated segments of the �88.8� display. See chart below.
    54 Control characteristics
    55 Outside (ambient) temperature, in deg C or deg F depending on setting on A/C control head
    56 Temperature in deg C, from Interior Temperature Sensor, in Headliner (G 86)
    57 Temperature in deg C, from Interior Temperature Sensor, in Instrument Panel (G 56)
    58 Temperature in deg C, from Fresh Air Intake Duct Temperature Sensor (G 89)
    59 Temperature in deg C, from Outside Air (Ambient) Temperature Sensor (G 17), front
    60 Temperature in deg C, from Ambient Temperature Sensor At Fresh Air Blower (G 109)
    61 Software version (latest)
    S3 Build Thread
  6. #485
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,377
    haha, and which of those codes are you thinking will show you IAT's Westy?
    I'm 98% sure they're all aircon related codes, aside from engine speed, cooland temp, and vehicle speed.....
  7. #486
    Westy's Avatar
    Dec 2008
    17,283
    What's number 4?
    S3 Build Thread
  8. #487
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    Would it not be
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
  9. #488
    Westy's Avatar
    Dec 2008
    17,283
    That's the same sensor as 4 mate.
    S3 Build Thread
  10. #489
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    As Nick has said, all this lot is aircon related and nowt to do with IAT's... G89 is a sensor used near the pollen filter IIRC...
    Thats why I have a Liquid gauge :D
    <tuffty/>
  11. #490
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    no4 is the fresh air intake temp, as Paul said, near the pollen filter
    Liquid logs IAT's on graphical form very nicely though, and you can freeze the graph at any point and take a photo to record results if you so wish.
    it does the same for actual vs requested boost too, which is very handly.
  12. #491
    Westy's Avatar
    Dec 2008
    17,283
    Oh for gods sake. I suppose I'll have to drive round with the laptop then.
    S3 Build Thread
  13. #492
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    hey! I want to undo my thanks...........
    Get your self a liquid guage!!..lol
  14. #493
    Westy's Avatar
    Dec 2008
    17,283
    Tough Dave.
    Stop making me spend money
    S3 Build Thread
  15. #494
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    I'm getting one....
  16. #495
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by Dane View Post
    I'm getting one....
    I'll just steal yours then.
    S3 Build Thread
  17. #496
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Tough Dave.
    you may as well, you have finished your mods for the time being, your wallet will think you are ill!!
  18. #497
    Westy's Avatar
    Dec 2008
    17,283
    I've still got things to spend money on.
    - Stage 2 next week
    - Brembos
    - Refurb wheels
    - Semi slick tyres
    maybe I'll add the liquid on the bottom here
    S3 Build Thread
  19. #498
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Good Lad....
  20. #499
    Dane's Avatar
    Cheltenham
    4,003
    Large port
    Frakenturbo
    New wheels around this point + tyres
    New oil filler assembly
    Liquid gauge
    ARBs
    polybushes
    LCR top mounts
    New tyres
    Another oil change
    SEM for the craic???
  21. #500
    Westy's Avatar
    Dec 2008
    17,283
    Large port
    Frakenturbo
    Liquid gauge
    ARBs
    polybushes
    LCR top mounts
    New tyres
    Another oil change
    Well you'll definitely need a liquid guage then to keep an eye on your engine as it'll probably blow up fairly quickly
    S3 Build Thread
  22. #501
    Dane's Avatar
    Cheltenham
    4,003
    Lol same old joke.... How are your rods, getting quite old aren't they
  23. #502
    Westy's Avatar
    Dec 2008
    17,283
    Deja Vu
    rods will be fine, it's clutch i'm worried about.
    Anyway enough of hi-jacking my thread lets abuse yours.
    S3 Build Thread
  24. #503
    Dane's Avatar
    Cheltenham
    4,003
    nothing happening there at the mo, might aswell!
  25. #504
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Please make something start happening Dane :P We got a lead today on a potential sale of something that could fund more shiney things!
    /Hijack over
  26. #505
    Westy's Avatar
    Dec 2008
    17,283
    Well it's happened! Some pikey kids have nicked my audi dust caps for their bikes. If I find them I'll be removing their testicles!
    The FMIC is also holding up quite well in today's heat but I think I have a slight boost leak somewhere as it feels like it's poising power after about 15PSI. I'll be nipping up all the clamps again.
    S3 Build Thread
  27. #506
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    Why didn't you get the ones with the little alan key for tightening them on?
    S3-2003-BAM-MING BLUE-SILVER LEATHER
  28. #507
    Westy's Avatar
    Dec 2008
    17,283
    Don't know. They were only £2 but it's the fact that they've been nicked on the driveway that annoys me.
    S3 Build Thread
  29. #508
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    That is cheeky, I got some with the alan key for £4.50 so not too bad and they can't get them off haha
  30. #509
    Westy's Avatar
    Dec 2008
    17,283
    Right, any guesses how long these ones will last before being stolen!
    AUDI A2 A6 Quattro S3 90 A3 A8 LOCKING VALVE DUST CAPS on eBay (end time 16-Jul-11 00:31:08 BST)
    S3 Build Thread
  31. #510
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    Just use plastic ones
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  32. #511
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by Sam_ View Post
    I refuse to have to use plastic one due to thieving little sh!tes who want them on their bikes. If these get nicked I will just put plastic ones back on
    S3 Build Thread
  33. #512
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Quote Originally Posted by S3MMA View Post
    I had a set of them once... the grubscrews rust and you can't get them out... fecked 2 valves in between tyre changes and gave up on them in the end... I used these due to pikey's pinching my previous set...
    Black plastic caps FTW lol...
    <tuffty/>
  34. #513
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    Get ones that say "F--- you little bastids" in the shape of the Audi logo
  35. #514
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I say so it South African style.... 10000 volts through them. If anyone touches them - k bye..... lol.
    Homer Simpson
  36. #515
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    lmao
  37. #516
    Westy's Avatar
    Dec 2008
    17,283
    I'll be keeping an eye on my car more often when the new ones are fitted. If I spot any kids even looking at them I'll chase them down the road with a huge knife
    S3 Build Thread
  38. #517
    S3MMA's Avatar
    Jun 2011
    Bolton, UK
    235
    Quote Originally Posted by GT30AudiS3 View Post
    <tuffty/>
    O dear I hope that doesn't happen on mine!
  39. #518
    Westy's Avatar
    Dec 2008
    17,283
    Guys,
    Going to order up my birthday present today Birthday isn't for 2 more weeks but I thought I'd get it before it goes. The question is, do I get GB badges or not???
    Number plate:
    S111 NPW
    S3 Build Thread
  40. #519
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Guys,
    Number plate:
    S111 NPW
    Yes, Deffo GB badges. Plates look plain without them.
    S3Lol likes this.
    Homer Simpson
  41. #520
    Westy's Avatar
    Dec 2008
    17,283
    That's what I was thinking plus it makes it look more modern. Getting legal pressed metal plates too
    S3 Build Thread
