AH FabricationsSky Insurance
Results 1 to 9 of 9
    Defratos's Avatar
    You’re Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    How to unhook the plastic engine cover??
    The title pretty much explains my question, after taking out the screws, how does the plastic hood unhook from the back of the engine?
    imported_micko2602
    Re: How to unhook the plastic engine cover??
    There should be 4 or 5 plastic fixings, which you give a quarter turn, then it should pull off.
    Defratos's Avatar
    May 2004
    2,230
    plastic fixings on the back? ok so turn clock wise or anti? =)
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    "unscrew" ... a qtr turn, although i am sure that it doesnt actually matter which way they r turned.
    nervus's Avatar
    Apr 2004
    1,160
    On the S3, there are only 2 plastic screws at the front of the cover. Undo these and pull the cover towards you and it will slide clear of the 2 rear tounge's. you'll see them once removed, refitting is fiddly but not difficult.
    May 2003
    North West
    202
    [ QUOTE ]
    [/ QUOTE ]
    exactly what he said for the S3, fiddly to put back the first time but much easier if you need to do it again.
    Mark
    Defratos's Avatar
    May 2004
    2,230
    Cool, thanks guys I've done it a couple of times now and know what you mean
    Aug 2003
    Christchurch, New Zealand
    47
    [ QUOTE ]
    Yep you need a super gigantic flat blade screw driver and then turn the 5 secureing screws a 1/4 of a turn in either direction and they will simply pop up, simply revers procedure to reinstall.
    [/ QUOTE ]
    I find small denomination coins work well if you need to do this when out bush. Handy for when your boot is full of crap and you need to disconnect the battery to reset your Symphony II which has crashed and hung [img]/ubbthreads/images/graemlins/ooo.gif[/img]
    Cheers,
    Edward.
    1,361
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    Cheers,
    Edward.
    [/ QUOTE ]
    Yeah the giant screwdriver is what I carry all the time now, along with just about every tool I need to stripdown the A3, but when I've forgotten the tools then I find the car key does the job [img]/ubbthreads/images/graemlins/shocked.gif[/img]
