Volks AutosEM Tuning
    Jul 2010
    bristol
    647
    rear wheel bearing = mot fail?
    just wondering if i'll get failed for this? one of my rears is just starting to make abit of noise 40mph+ i need to get the car in for its mot in the next few weeks so dont know weather i should get the bearing done before or will it be ok to leave it a few weeks?
    99' a3 quattro - k03s, carbonio cai, simota cone filter, FMIC, raceland coilovers, fully polybushed, forge TIP, forge 007p, forge coolant hose kit, forge throttle body pipe, stainless catback, brembo pads, stage one map, black angel eyes, 17" radius r3's gt28rs coming very very soon
    beachbuggy's Avatar
    Surrey
    1,745
    No,
    If it's noisey it will be an advisory, It will only fail if there is side to side or top to bottom play. If it only happens over 40 then I very much doubt it's failed enough to fail the mot.
    Jack the car up and try moving the wheel, it should be solid, which it probably will be.
    Jul 2010
    bristol
    647
    spot on as always thanks alot mate
