Sky InsuranceBadger5
    ben4866's Avatar
    Oct 2009
    Keighley, West Yorkshire
    32
    Failed timing belt tensioner
    I fit a new SKF t.belt kit and water pump on my A3 1.8t AGU and I have done roughly 3K miles since and it appears that the new tensioner has failed already ! There looks to be a dark greasy substance on the tensioner and I could probably push the belt off the cam sprocket quite easily !
    My question is has anyone else heard of or experienced this happen with a new tensioner ?
    And I suppose I won't be able to buy a new tensioner by itself ?
    Any help much appreciated.
    Regards
    Ben.
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    Yep ive seen it on a TT, the tensioner wasnt as new as yours but it does happen!
    You can buy the tensioner no problem from vag. You could try the manual fixed tensioner from Integrated engineering if you want to upgrade.
    Audi S3 1.9 GT30....
    ....that is all
    S3KO4's Avatar
    Aug 2009
    London
    850
    I have a spare tenssioner from an APY if it is any use to you.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
