Sky InsuranceJMB Retrofits
Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By superkarl
  • 1 Post By S3KO4
Thread: S3 Feels Slow
    lukejenks's Avatar
    Nov 2010
    57
    S3 Feels Slow
    Hi i have had my s3 for about 7 months now, it has fmic, induction kit, forge split-r and i was told by the previous owner a revo stage 1, it doesnt feel very fast though, a mate has a standard ep3 civic type r which makes it look silly!
    Now after doing the n249 bypass yesterday i noticed a big hole in the breather pipe that comes from the cam cover to the air trunking etc
    This is the pipe.
    Could this be causing a power loss?
    Also will these pipes fit or no? I have an apy engine code
    Forge Motorsport | Alloy Fabrication
    2000 Imola Yellow S3
    Feb 2011
    24
    Dunno about your engine, mine is an amk and I have had to fit the forge one you listed recently. Looks like a similar pipe. I had a very small hole in this pipe and yes it does make a difference to power. What I would say about replacing it is that the plastic pipe that goes down towards the front of the engine was very brittle and broke when I tried to push it into the forge pipe. Might be worth replacing that at the same time.
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    Change the PCV valve aswell while you're down there changing the breather hoses. Get the Forge breather hoses, i done mine last year aswell. The PCV valve is also known as the 'Engine Block Breather Hose' to Audi dealers by the way just in case they can't find it on their system!
    I've got an AMK S3 and the Forge breather hoses fit on mine. Someone else on here will verify if it will fit your APY.
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    lukejenks's Avatar
    Nov 2010
    57
    I just spoke to awesome gti and they said its impossible to fit that pipe to an apy engine, i have ordered a new genuine one anyway, only £21.
    Are the pcv hoses these ones? Forge Motorsport | Alloy Fabrication
    Do you replace the valve as well or just the hoses?
    Feb 2011
    24
    'scuse my ignorance (i don't want to hijack) but is the pcv valve the large black valve that connects to the split pipe pictured above?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Yes it is. Id be inclined to change your forge split r, thwse engines are designed to be run with recirculating dump valves e.g 007p
    Inertiauk likes this.
    S3KO4's Avatar
    Aug 2009
    London
    850
    why would you change the valve! just give it a good clean and put it back. worked for me.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Inertiauk's Avatar
    Mar 2011
    529
    My S3 Felt slow and I had the same problem, I replaced all of the PCV pipes, sealed it all up, and it no longer smells of oil, however this didn't speed up my car, it turned out to be a boost leak where the terracotta pipe from the charge pipe connected to the turbo, I replaced this with a forge one and stronger clips which cured my slowness problem.
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
    lukejenks's Avatar
    Nov 2010
    57
    I only got the split r as it was £30. I'm gonna try changing all the hoses eventually. The car does spool up quote loud. Is there anyone in Bristol who wouldn't mind taking a look?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by fast_eddie_s3 View Post
    Do you mean the valve below? If so then this is not the PCV valve, the PCV valve is under the intake manifold
    Jul 2010
    bristol
    647
    where in bristol are you mate?
    99' a3 quattro - k03s, carbonio cai, simota cone filter, FMIC, raceland coilovers, fully polybushed, forge TIP, forge 007p, forge coolant hose kit, forge throttle body pipe, stainless catback, brembo pads, stage one map, black angel eyes, 17" radius r3's gt28rs coming very very soon
    Feb 2011
    24
    yeah, that's the bugger. what does it do?
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    crankcase breather pressure regulating valve, i think its a one way valve
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Enjoy!
    lukejenks's Avatar
    Nov 2010
    57
    Yeah its the one in sandips picture. I am in henbury mate
