very low on coilovers. with adj drop links.
4rings
NULL
hi people. looking for those who nhave lowered there a3 ALOT :).
basically i have fk coilovers which are set pretty low. and i also have the adjustable drop links to be able to give clearence on the driveshaft
should the drop links be adjusted so they push out or pull in?? i.e wound out e.t.c becuae no matter how i adjust the drivers side it still grinds against the driveshaft.
i am having a eibach 25mm front anti roll bar fitted soon. and apparently they have a bigger loop to accomodate really low cars??
yeah the drop links dont actually work i dont think, the new arb will sort your problem out
Or if you want to go really low an LCR front ARB goes underneath and then you can slam it down to the sills :greyrs4:
well i will try the eibach arb i have in my bedroom. just gotta wait 2 get paid n have it fitted.
whats an lcr front arb?? im a bit lost lol sorry :(
Are you putting on a rear ARB as well?
ahh i see ok. well ill try the eibach one if no joy then ill rethink e.t.c.
i will be upgrading the rear one but not yet
