AGU-TURBO
Audi a3 1.8t AGU
- Joined
- Apr 29, 2010
- Messages
- 604
- Reaction score
- 7
- Points
- 18
Check you'r cars mot history For anybody that doesn't no about it here is the link:
Well guys n girls ive just sold my van and the bloke who bought it thinks it has been clocked. i did do a full £10 my car check.com before i bought it and it came back saying everything is fine
here is what it says:
Full Test History, starting with first recorded vehicle and test results
Registration mark:R501PBLMake/ModelEUGEOT / PARTNER 800Colour:WHITEVIN/Chassis No:VF35CD9BD60091185Approximate date of first use:20/03/1998Type of fueliesel
Date of test:06/12/2006Certificate issue refused (Fail)
Odometer reading:180,425 MilesTest number:411550246499Test station name:TYRE & AUTO CENTRETest station number:6822A3Test station telephone number:01914892295Test class:IVReason(s) for refusal to issue Certificate
Nearside Registration plate lamp not working (1.1.5c)
Nearside Stop lamp not working (1.2.1b)
No Advisory Notice issued
Date of test:06/12/2006Certificate issued (Pass)
Odometer reading:180,425 MilesTest number:460510446385Test station name:TYRE & AUTO CENTRETest station number:6822A3Test station telephone number:01914892295Test class:IVTest expiry date:05/12/2007No Advisory Notice issued
Date of test:23/08/2007Certificate issued (Pass)
Odometer reading:85,018 MilesTest number:344935737258Test station nameERFORMANCE CARSTest station number:V100657Test station telephone number:0191 4242302Test class:IVTest expiry date:22/08/2008No Advisory Notice issued
Change of details
Make/ModelEUGEOT / PARTNER recorded at time of test on 23/08/2007
Date of test:26/09/2008Certificate issue refused (Fail)
Odometer reading:69,173 MilesTest number:282350278203Test station nameARKERSTest station number:29372Test station telephone number:01915672274Test class:IVReason(s) for refusal to issue Certificate
Both Front position lamp(s) not working (1.1.A.2b)
Front both Brake disc(s) excessively pitted (3.5.1h) **DANGEROUS**
Nearside Rear Brake pipe excessively corroded (3.6.B.2c) **DANGEROUS**
Brake load sensing valve linkage seized (3.6.E.4) **DANGEROUS**
Offside Front Coil spring corroded (2.4.C.1b)
Change of details
Make/ModelEUGEOT / PARTNER 800 recorded at time of test on 26/09/2008
Date of test:29/09/2008Certificate issued (Pass)
Odometer reading:69,177 MilesTest number:311133778280Test station nameARKERSTest station number:29372Test station telephone number:01915672274Test class:IVTest expiry date:28/09/2009Advisory Notice issued
Date of test:07/09/2009Certificate issue refused (Fail)
Odometer reading:11,754 MilesTest number:442330459253Test station nameCK + L AUTOS LIMITEDTest station number:V100523Test station telephone number:01246825960Test class:IVReason(s) for refusal to issue Certificate
Nearside Front position lamp(s) not working (1.1.A.2b)
Offside Outer Front constant velocity joint gaiter split (2.5.C.1a)
Nearside Outer Front constant velocity joint gaiter split (2.5.C.1a)
Rear Tyre(s) is incorrect because different size tyres are fitted on the same axle. (4.1.A.1a)
Offside Front Direction indicators slightly discoloured (1.4.A.2d)
Exhaust has part of the system slightly deteriorated (7.1.1a)
Change of details
Make/ModelEUGEOT / PARTNER recorded at time of test on 07/09/2009
Date of test:25/09/2009Certificate issue refused (Fail)
Odometer reading:117,578 MilesTest number:773338169254Test station nameCK + L AUTOS LIMITEDTest station number:V100523Test station telephone number:01246825960Test class:IVReason(s) for refusal to issue Certificate
Nearside Front All position lamps not working (1.1.A.2b)
Front number plate has slight damage
Date of test:25/09/2009Certificate issued (Pass)
Odometer reading:117,578 MilesTest number:660418669260Test station nameCK + L AUTOS LIMITEDTest station number:V100523Test station telephone number:01246825960Test class:IVTest expiry date:28/09/2010Advisory Notice issued
Date of test:11/09/2010Certificate issue refused (Fail)
Odometer reading:122,320 MilesTest number:681064050295Test station name:HILLSIDE GARAGETest station number:1ALK81Test station telephone number:Tel. 01246 828790Test class:IVReason(s) for refusal to issue Certificate
Rear Exhaust system not adequately supported (7.1.1b)
Rear Spare wheel carrier insecure (6.4.2)
Nearside Outer Front constant velocity joint gaiter deteriorated (2.5.C.1a)
Offside Inner Ball joint has slight play (2.2.B.1f)
Nearside Inner Front wing Body has slight corrosion (6.1.3)
Offside Inner Front wing Body has slight corrosion (6.1.3)
Engine/gearbox mounting(s) defective
Oil leak
Date of test:14/09/2010Certificate issued (Pass)
Odometer reading:122,352 MilesTest number:723767450296Test station name:HILLSIDE GARAGETest station number:1ALK81Test station telephone number:Tel. 01246 828790Test class:IVTest expiry date:28/09/2011Advisory Notice issued
Oil leak
tell me what you all think, there is definetly mistakes been made by MOT testers at some point but it goes abit beyond that me thinks. let me no you'r thoughts
