Results 1 to 10 of 10
    Mar 2011
    Exeter
    90
    Forge alloy boost pipe, any good?
    hi guys, was just looking through the forge website and came across this:
    Forge Motorsport | Alloy Fabrication
    has anyone got one fitted? i was wondering if its a worthwhile upgrade?
    thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Thats just bling tbh.... ideal if you are detailing your bay but beyond that will add nothing to power... I still use the original on mine and I run a much larger turbo than std...
    <tuffty/>
    Mar 2011
    Exeter
    90
    ah i thought as much, it says there is a silencer on the standard one?
    also how about dv cold side relocation kit? the benefits sound like a bs to me. any thoughts?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Silencer does little more than hide the turbo whistle... people have removed the silencer from the std charge pipe but does very little other than make it a little nosier and is a bugger to do.. there are a couple of threads with details of this already...
    Cold side is a little gimmicky tbh... it does work in so much that the DV is moved away from a heat source making it (questionably) more reliable and there is the belief that the cooler air being dumped post intercoolers helps keep the overall charge air cooler but I can't see it making that much difference especially if you don't have a decent FMIC in the first place... this will always be better than a coldside kit... again its nice bling IMO but I would save your money for something thats more beneficial like a decent FMIC, 3" DP etc...
    <tuffty/>
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    Awesome, theyve finally brought it art . .
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    £100 does it come with a free tube of KY jelly to soften the blow?
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    I smashed the baffles out of the standard charge pipe silencer and it was such a pita! I wouldn't bother doing it again. You live and learn.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Speedy Steve View Post
    No, you need that at the point of sale, as per Forge standard operating procedure...
    Homer Simpson
    Mar 2011
    Exeter
    90
    How about one of Forge's uprated actuators? anyone running one? im thinking its not necessary as the n75 controls the actuator anyway??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    No need to use a Forge actuator on a K03/4 turbo unless yours is buggered... even then you would still use the same rate of spring as fitting a higher rate buggers up the boost control and these turbos aren't man enough really... only time I have seen a higher rated actuator used is on hybrids and even then your are only looking at 0.8bar
    <tuffty/>
