EM TuningMonster Motorsport
Results 1 to 7 of 7
    audi S3
    Mar 2009
    Elgin/scotland
    7
    can you decode brakepad wear sensor
    having some trouble with my brake pad wear light on my s3 can it be decoded
    27,099
    Trouble as in?
    Why not just fix it fully or have you got aftermarket brakes?
    audi S3
    Mar 2009
    Elgin/scotland
    7
    iv got brembo kit on. it was fine then the light just appeared.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,274
    You can just join the two wires together and tape them. This creates a circuit and doesn't allow the light to come on.
    It sounds to me like yours may be like that when the brembo kit was put on but the two wires have come apart now. Check for the wires by your brake calliper.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    audi S3
    Mar 2009
    Elgin/scotland
    7
    iv checked the wires and striped them back and joined them again still no joy thanks anyway
    gavin89's Avatar
    Wana go Low gotta go Slow
    Bournemouth/Manchester
    214
    Pull the plug out, stick a 1k ohm resistor across it then check. If it goes off, then the internal resistance of the pads is out of range therefore causing the light to come on.
    audi S3
    Mar 2009
    Elgin/scotland
    7
    the plugs been removed for some reason but thanks anyway
