AH FabricationsBadger5
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By Prawn
  • 1 Post By 16Klappe
Thread: r-tech at last!!!
    A3tell's Avatar
    Jun 2009
    essex
    239
    r-tech at last!!!
    well, the time has finally arrived, r-tech in the morning!!!! now i would be quite excited about it if it wasnt for the fact that i think my car is running a little ritch!! and i cant seem to get to the bottom of it!! do you think that they might turn me away if it does turn out to be so????
    i hope not, i will be gutted!!!
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,061
    Visit 16Klappe's Instagram Channel
    Quote Originally Posted by A3tell View Post
    TBH with you, they may well. If there are boost leaks and the car is not in good nick they won't map it, which is harsh but shows they care.
    Have you not thought to have had it checked over before the map? Vagcom'd it at all? What makes you think its running rich?
    I quite often say I'm going to do things.
    Then never do them.
    Loupigs's Avatar
    69
    They gave us a right roasting for the state mine was in :-( Make sure you've got no boost leaks, using the right oil and VPower. Mine was full of leaks and despite being serviced properly since I've had it apparently it had crap oil before and was just generally full of gunk. All fixed now though and the map is brilliant. To be fair Nick was dead right saying he was reluctant to map it because the turbo was working so hard it kept going into limp mode until we fixed it. Bit scary at 90mph on the M3 wedged between a Merc and an Impreza! Serves me right for neglecting the car for six months when I was skint and expecting to take the sudden power upgrade without a bit of TLC really!
    You aren't stuck in traffic.... You are traffic
    A3tell's Avatar
    Jun 2009
    essex
    239
    car has been checked, i even spent over £200 last week to get a dodgy looking water pipe replaced, and not any pipe, the main feed metal pipe that comes off the block and feeds everything else!! part was £135 on its own, at same time i got them to do oil+filter change, with an oil nick recommended, main dealer quantum platinum! £30 for 5 litres. and also to stick on the scanner which threw up NO fault codes and also to check that my boost seemed ok, is peaking at around 7.5-8 psi dropping off slightly at top end, which they said seemed ok! but have had no time to get system smoke tested to be 100%. the reason i think she may be running slightly lean is there is a small fuel smell when the car is cold. any other thoughts???
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,061
    Sounds perfectly normal to me.
    All the things you have mentioned are just routine maintenance, you should be fine with a map is its holding good boost and has been serviced. When was the cambelt and water pump done last?
    It's addictive though, a stage 1 won't be enough. You'll want more and more!
    Then never do them.
    A3tell's Avatar
    Jun 2009
    essex
    239
    i know what you mean..... lol already got planes for the fmic and 3" downpipe and full system, obviously followed by a custom map,maybe even go ko3s............... water pump failed last summer!!!! (*****) so had that changed for a metal one, and belts at the same time, so only a few thousand miles on it!!!! still cant get to the bottom of the fuel smell, just hope it isnt something thats going to stop me having it done, cos its a 6.5h round trip to r-tech for me!!!! which is y i got as much checked as i could!
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,061
    I went from Plymouth to Basingstoke, to R Tech, to Basingstoke to Plymouth for my trip to R-Tech haha!
    Ahhh, well if its only an AGU you will want a KO3S to chase some real ponies. I'm guessing its a pretty standard car ATM, a good route would be 007P and air filter, silicone TIP, decat and downpipe. With maybe a set of coilovers, ARB's, poly dogbone mount and S3 brakes up front. Then when you get bored swap him over for a KO3S with an FMIC and a stage 2 map and you should see the best part of 240bhp and will have a tidy little car. The AGU head is actually better than the AUM, so really you've got a good base to start from
    Then never do them.
    A3tell's Avatar
    Jun 2009
    essex
    239
    lol, thats a bloody long journey!!!! not standard now, first thing i done was 007p, then have already fitted new discs and pads all round, drilled and vented! then few weeks ago, fitted my forge tip+ jetex cone filter with a home made cold air feed and diy heat sheild for the filter, and hid's too. so already spent a few £s, plus all the damn repairs i have made since i got here 2 years ago! so am well on the way......
    Loupigs's Avatar
    69
    Stop saying 'my' trip to R-Tech Pigs!!! It's MY sodding car! You drive a Peugeot!
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,355
    haha, shot down and denied!
    Good luck tomorrow matey
    Should be great!
    A3tell likes this.
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,061
    Quote Originally Posted by Loupigs View Post
    Well seeing as I drove it there and I paid for it I guess it was my trip, back in your box woman.
    Prawn likes this.
    Then never do them.
