AH FabricationsEM Tuning
Results 1 to 9 of 9
    Jan 2011
    Glasgow
    226
    Flat spot low RPM
    Recently my S3 has been hesitating for split second around 1800RPM - 2000RPM while driving i can feel it and its starting to annoy me. On the journey to work today i noticed the engine while sitting still at traffic lights sometimes vibrates the car like a V8. Again for a second on idle. The needle does not sit still either on idle not weavering fast just very slight movement up and down. Car pulls fine above 2500RPM but seems a little reluctant lower down.... Any suggestions? MAF?
    Jul 2010
    bristol
    647
    possibly a coilpack on its way out mate
    99' a3 quattro - k03s, carbonio cai, simota cone filter, FMIC, raceland coilovers, fully polybushed, forge TIP, forge 007p, forge coolant hose kit, forge throttle body pipe, stainless catback, brembo pads, stage one map, black angel eyes, 17" radius r3's gt28rs coming very very soon
    Jan 2011
    Glasgow
    226
    Had Audi do the recall few days back two were replaced and other two were fine.... :S
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    I had a similar issue that turned out to be maf. Unplug it and see if the car drives any smoother.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Jan 2011
    Glasgow
    226
    Is that simple to do? How can i do that i'm no mechanic :P
    Westy's Avatar
    Dec 2008
    17,156
    Ok I'll try and describe it the best I can without a photo.
    I'm assuming you Know what and where the airbox is on the right of the engine bay? Well the hose that comes directly out of the air box will have a connector plugged into the top of it. Just unplug this and the car will run off of default data on the ECU instead of using the MAF reading.
    This won't do any harm at all to the car. If your car feels a lot smoother with the MAF unplugged then it's probably had it.
    S3 Build Thread
    Jan 2011
    Glasgow
    226
    Ok i know where the air box is yeah... will give it a try
    Jan 2011
    Glasgow
    226
    Took out the MAF sensor... pulls like a train at low RPM now :P Think cleaner will sort it or just a replacement? How longs a piece of string? :P
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,059
    Nothing to lose, try cleaning it....
