Badger5Volks Autos
Results 1 to 15 of 15
    Jul 2010
    111
    Headlight Washers
    Hiya ppl,
    Ever since i got my S3 the headlight washers have not worked? any ideas what this could be as i know there just operated on water pressure but they dont come out of the bumper?
    lee
    2001 S3 AMK. Viper Remap, Forge 007P, Carbon fibre engine cover, SFS TIP, Tints, Forge Breather Hoses, Auti R8 oil Cap, Leon CPR Top mounts, S3 car mats, German number plates. 249 By Pass mod
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,263
    How have you checked them? They only come out when you're going along and you spray the washers. They also only work on pressure, no motor involved.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    only with the lights on dude as well
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    Jul 2010
    111
    Thanks for the replies will they work when stationary with headlights on?
    Westy's Avatar
    Dec 2008
    17,263
    Quote Originally Posted by IOM-S3 View Post
    Hmm, I'm going to try this when I get out to my car
    S3 Build Thread
    Jan 2011
    Glasgow
    233
    Yes they work stationary...while holding the washers for 3 - 4 seconds with lights on.
    Jul 2010
    111
    right cheers for that, in that case mine dont work
    talentwalsh's Avatar
    May 2010
    Galway
    139
    There is a seperate water pump for the headlight washers to the window washers, hence the reason they dont both come on all the time. The pumps are located in the water bottle and have a tendancy to go. Its bloody tricky to get to the pumps though due to the knuckle removing lack of space!!
    kelk11's Avatar
    Feb 2009
    102
    The Fuse went on my through the winter when they had frozen, new fuse problem sorted. Worth a check
    Jul 2010
    111
    Thanks guys is the fuse located in the interior fuse panel?
    S3KO4's Avatar
    Aug 2009
    London
    850
    more often it is caused by bent hose, previous owner / mechanics could have bend the hose behind the front bumper and that stops pumping any water at all, no water means it wont even rise up.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,053
    Fuse is in the interior fuse panel, i had mine go in the winter.
    They will also only work when the headlights are on, not just side light, you need the lights fully on.
    Press the washer in for a few seconds and they should work, will also work on stationary, you dont have to be moving.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Correct..^^^
    Jul 2011
    FLORIDA
    hi yall,
    i have the same problem the washer only works on the headlights when they are on and not on the windshield at all. can figure it out at all anyone else have something similar
    May 2010
    Galway
    139
    There is a seperate pump for the windshield and the headlights. Your headlight pump is probably goosed. There prone enough to failure.
