Volks AutosChris Nott
Results 1 to 19 of 19
    stacey bear's Avatar
    ST8C3Y
    Apr 2010
    Cambridgeshire
    187
    Smile Newly painted calipers... With pics.
    Happy Easter to all at Audi-Sport, hope your enjoying the weather.
    Well the time has come and I've just spent most of my easter sunday painting my calipers and cleaning my wheels, followed by a BBQ and some cold beers..
    Here are the pics.....
    Cleaned inside and out...
    Oh I would like to add, if I had silver or black paint I would have done the carriers and the holding pins either of those but reds good for now...
    Front Wheels and calipers all done.
    Again I'd like to have done the carriers black....
    Rears all painted and clean.
    All polished and painted. Job well done if I dont say so myself...
    Ming Blue 1.8t 1999..
    Feb 2008
    2,817
    Good job mate.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    GeneralWest's Avatar
    Sep 2009
    Cambridgeshire
    168
    Good effort. I want to do my callipers soon.
    Now: 2001 S3 Nogaro Blue
    Then: 2000 S3 Black
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Good job that pal they look well behind your wheel. Think I might do mine next week when I have a go at polishing my wheels! What paint did u use?
    IF IN DOUBT FLAT OUT---iF U AINT RUBBIN U AINT DUBBIN
    ST8C3Y
    Apr 2010
    Cambridgeshire
    187
    Thanks Wayne1.8t, i just use hammerite smooth paint. Got two lots of the 250ml tins and have only used 1/4 of 1 tin. I did 1 caliper at a time. Just did a quick once over with a small wire brush, one coat of paint, then washed the wheel in and out with some swafega alloy cleaner then back of to give the caliper another coat then stuck the wheel back on. I worked round all four wheels in the same way. It took about 4-5 hours in total with little breaks inbetween tho.
    Odt
    Apr 2011
    Bristol
    61
    Nice job, doing mine tomorrow did you spray or brush?
    ST8C3Y
    Apr 2010
    Cambridgeshire
    187
    I used a brush, the brush marks dont show, i didnt take off the calipers and housings so its not the best of finishes..
    ST8C3Y
    Apr 2010
    Cambridgeshire
    187
    Sorry S3 RAV didnt mean to give you a dislike.
    Odt
    Apr 2011
    Bristol
    61
    I'm going to try spraying, chosen gloss black for mine after the subtle look, brush marks aren't visible might try brushing if I get frustrated
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Defo will be having a go now seen yours, will take my calipers of thoe I no what I'm like with a brush it will be everywhere.ha
    Are you gona do the rears aswell?
    If u haven't already that is
    Edit: just noticed your last pics they must not of loaded up b4.... They look great not sure what colour to go for myself.. Yellow or red I was thinking.. Hmmmm
    ST8C3Y
    Apr 2010
    Cambridgeshire
    187
    I think it depends what colour your car is. I put a post up a few weeks ago and asked for opinions. Red came up alot. I'm glad I went with red, it does suit the car. Yes a brush can be messy, I found a small ish one about 1/4 to 1/2 in wide. Was a cheap one tho but done the job.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Mine are getting done in satin black soon as they're a bit manky!
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Jan 2011
    N.Ireland
    149
    Nice work i did mine last week, used hammerite aswell. Using a brush is the only way to do it imo, the spraying doesn't seem to stick well
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Did my front ones today I took the calipers off to do them. I've put them back on but have no brakes.
    I'm going to bleed them as I lost a little fluid.
    Do I just bleed the 2 calipers or the master cylinder or do I do both???
    ST8C3Y
    Apr 2010
    Cambridgeshire
    187
    You should be ok to just bleed the calipers youve took off. I'd make sure you don get to much fluid on your freshly painted caliper tho as brake fluid is a great paint stripper. A good wat to bleed your brakes is to get hold of an empty plastic milk bottle and lid (one of the small ones, think there 500ml) and put a piece of pipe (fuel hose) through the lid. Fuel hose is the right size to fit over the bleed nipple quite snug. This way all your fluid will go into the bottle and you'll be able to see any air as youll get bubbles in your bottle.
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Great thanks alot I'll do it in the morning, gona do my backs aswell didn't have time today. Hopefully won't be as dirty as the front they were a pain to clean up.
    I'll get some pics on 2moz
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Got them finished today. Spent most of the day bleeding my brakes which wasn't fun had trouble with the nuts on the bleeding nipple. All good now
    Just gona keep them clean now I don't fancy doin it again in a hurry.
    ST8C3Y
    Apr 2010
    Cambridgeshire
    187
    Well done wayne1.8t. They look really good behind your rims. You've done a good job mate.
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Cheers pal! does look better now just look small now there more noticable imo.
