EM TuningSky Insurance
Results 1 to 16 of 16
    S3-Oski's Avatar
    Nov 2008
    Essex
    480
    Smile Sump and Oil pickup clean?
    Hi, My car is up for a service, but I would like my sump cleaned and oil pickup cleaned, at the same time.
    How easy a task is this? If I took it into a local mechanic, would they have the stuff I need for it? Or would I need to order the bits for it?
    Or if there is anyone around Essex area who is competent enough at doing this, I would happily pay what it costs? Its something I do not think I would attempt myself.
    2001, Ming Blue, Aluminium Mirrors, Revo!, Bose, Parking sensors, Sunroof,
    stacey bear's Avatar
    ST8C3Y
    Apr 2010
    Cambridgeshire
    187
    Its not a hard job, im going to do mine asap, you'll need some brake cleaner and some good gasket sealer as theres no sump gasket, its just silicon. If you do do it make sure you get an even amount of sealer round your sump before you re fit it. You'll need your oil and filter too. Most car parts places will have those in stock as there a common filter and grade of oil...
    Ming Blue 1.8t 1999..
    beachbuggy's Avatar
    Surrey
    1,745
    Not a hard job, shouldn't take more than 1.5 hours.
    You need a 5mm long reach ball jointed allen, silcone sealant, such as hylomar blue, a degreaser and a socket set.
    My biggest tip is to remove the 3 allen bolts located next to the sump first, these are a right PITA and there's no point removing the other 19 bolts if you can't get these out. So do these first just to make sure you're not wasting your time.
    S3-Oski's Avatar
    Nov 2008
    Essex
    480
    Quote Originally Posted by stacey bear View Post
    Thanks mate, If anyone reads this and is around Essex, and can/wants to do this, I will happily pay what it costs, cheers
    barters3's Avatar
    May 2008
    440
    S3KO4's Avatar
    Aug 2009
    London
    850
    Don't forget the oil return gasket, or if you are like me just use the same sealant all round.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    S3-Oski's Avatar
    Nov 2008
    Essex
    480
    Quote Originally Posted by barters3 View Post
    Thanks, I will Definately get someone to do this for me I think! Anyone??? Lol
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    My advice is to just buy a new pickup pipe form Audi.
    They are about £14, and that way it is CLEAN, not semi clean. I have tried cleaning out a pickup pipe, and you don't get as good a result as when you install a new one.
    Do it right, do it once.
    Homer Simpson
    Apr 2011
    197
    to do this completely remove the rocker cover and scrape the crap out
    remove the engine breather and clean it out also replace the pipes
    replace the turbo pipe feed pipe
    scrape the sump out
    clean the strainer out
    flush the oil through with some cheap oil
    reassemble fit a cheap filter and fill with cheap oil
    run to normal temp and drain it
    now fit oem filter and long life 3 oil or mobile 1
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    Exactly what i was gonna say. Buy a new one from Audi.
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    Apr 2011
    Cardiff/Barry
    Sorry to point out the obvious guys, do all of the above if you fancy, but if you invest in a good oil additive/flush, add it to the oil through the filler cap, run ther engine for a good 15 mins, it not only cleans out the sump and strainer, but does all the internal galleries and the top-end at the same time. I've stripped the bottom end of a few Audi's after servicing with a good flush, and they've been spotless - brand new even. Cheaper alternative than parts and labour for the entire sump and strainer. Good flush cost about £10-15. Have a look about on t'internet for a good flush....
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,522
    Quote Originally Posted by dmac626 View Post
    not all depostis can be removed with flush sadly, if it were as simple as adding a flush, don't you think we would take the easy option? LOL
    S3-Oski's Avatar
    Nov 2008
    Essex
    480
    Hi all, Does anyone know a good place/anyone in Essex that would do this for me in the next couple of weeks? Thanks.
    Apr 2011
    Cardiff/Barry
    Stripped bottom end off an A4, an S3 and an R8 after flush. A4 had 78,000 on it, S3 near 100,000 and the R8 about 18,000. Surprised me chief. Were absolutely brand new. Went on to do the top end on the S3....same thing. Galleries were gleaming, no sign of the usual ****e everywhere. I've got a crap old Peugeot as a run around and flushed that before fixing the bottom end. Same story. Might just be jammy...???
    Oct 2010
    Hampshire
    294
    dmac626 - were the A4 and s3 on long life servicing or annual/10k. My S3 is on 93k, oil has been changed every 10k so wondering if it is just cars on longlife that suffer from a blocked pickup or if I should do it when i next change the oil.
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Thanks for the advice, certainly can't do any harm if it doesn't work I'd imagine. Can you recommened a good product?
    You only really appreciate how retarded people are in this world when you log on to a forum and recoil in disgrace over their spelling. How are any of you actually employed?!
