Sky InsuranceEM Tuning
Results 1 to 10 of 10
    Apr 2011
    6
    problem witch speedometr a3 8L
    hi all, I have a problem with my speedometer 1.9TDI a3 8l, marks an approximate speed and only when he wants, at first thinkthat it was speedometer, byt now i change it. I've noticed that when you floor the accelerator the speedometer is showing signs of marked and sometimes make, but when I let the high speed needle down.And a change the speed sensor that goes in thetransmission.I put an cruise control bat it only lasts 1 or 2 minutes or in some cases last longer then the car starts to stick pulled and removed cruse control. The vag com does not fault, well it gives an incorrect key programing but I think it has nothing to do with the problem.
    to see if you give me some clue where I can begin.
    Greetings.
    some video
    Jan 2011
    Glasgow
    226
    Could possibly be a bad earth?
    Apr 2011
    6
    how i can see it? where is the ground of speedometr?
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    3,991
    does your fuel gauge give inaccurate readings aswell?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Are you checking the right modules in VAGCOM to test this? try doing a full scan if you haven't already...
    Whats the flashing dash light? somethings not happy...
    <tuffty/>
    Apr 2011
    6
    yes witch old speedometr, but since i chenge it it work fine.
    Apr 2011
    6
    in the vag scan i have only one fail
    Jan 2011
    Glasgow
    226
    The main ground for the car not the Instrument cluster....
    Apr 2011
    6
    up...
    Apr 2011
    6
    where i can see the ground of instruments cluster?
