Volks AutosSky Insurance
Thread: s3 idle speed
    Feb 2011
    southampton
    229
    s3 idle speed
    can any one plaese tell me what my s3 should idle at i have used vag com and it is 720-760 when on idle . and i think this is a bit to low can any one tell me what theres is idle in at please
    casue its a bit lumpy on idle but if i put fans on ect is fine and engine idle slightly high when there on as engine works harder
    or is there a way i can adjust the idle using vagcom
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    Mine idles at around 1100 till its warmed up then it's the same as yours.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,450
    ^^ same as above. Cleaning throttle body can help smoothen idle, and cleaning injectors improved my idle hugely.
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Vac leak will also affect idle - the larger ones tend to bring the idle down.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Feb 2011
    southampton
    229
    ok guys i have cleaned the throttle body , how easy is it to get injectors out to try that , also whats the easyest way to find vac leak
