Monster MotorsportVolks Autos
Results 1 to 18 of 18
    Mar 2011
    22
    HELP!!! SOUNDS LIKE IV GOT A SECOND TURBO??
    When I put my foot down, usually from low revs, I get a loud whining sound that is defently not the turbo?? Sounds like it might be a bearing but which one? I don't get the noise when I drive easy.
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    is the whining coming from front or rear?
    Mar 2011
    22
    It's coming from the front. I thought it was the gearbox, so I ordered a Reconditioned gearbox. Took out my old gearbox and realised not only were the gearboxs different, but the engine mount was dangerously loose and about to slip off??? I put back the old gearbox and tightened up the engine mount best I could, which felt really good and dosent give me any trouble to this day. And with the old box in the noise has gone away??? That was about a month ago and everything was fine until now!! The noise has come back! Not as loud but its there. I thought because the mount had dropped, that it was putting extra strain on the driveshaft?? Help i don't really wanna buy a new gearbox again as it took me a month to get my refund. Any ideas?
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    does it sound like the video at the top of this thread?
    whoopiee cushion noise
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Thrust bearing would be my first look
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,263
    Quote Originally Posted by Dane View Post
    I hope it is that that's the problem as it's easy to fix and I so happen to have a brand new Forge hose going cheap
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Dane's Avatar
    Cheltenham
    4,003
    Quote Originally Posted by Westle View Post
    Shameless plug lol.
    Your description of the problem does sound fairly similar to my symptoms, fine off boost, but when you put your foot down much louder wooshing turbo noise and where the air from the turbo was escacping from the the pipe it made a whistley whiney whoopie cushion noise.
    Mar 2011
    22
    No its defently not the turbo leaking. More likely to be the trust bearing but when I hear the noise I press the clutch and dosent really make much difference. It's only under load.
    Mar 2011
    22
    It only happens in 1st and 2nd gears tho??
    Mar 2011
    22
    No ideas anybody??
    Westy's Avatar
    Dec 2008
    17,263
    Quote Originally Posted by dandos View Post
    No ideas anybody??
    It's extremely difficult to give any advice really bud. Can you get a recording of the noise and post it up?
    Also does the sound go away when dipping the clutch?
    Have you had a mechanic look at the wheel bearings?
    S3 Build Thread
    Mar 2011
    22
    I understand that its difficult to diagnose a noise but the fact I took out the gearbox and replaced it and the noise went away? What could that be?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    If it only does it in 1st and 2nd it HAS to be the box.
    Mar 2011
    22
    So would taking out the gearbox and changing the oil stop the noise for a while?? At the moment its only really in 1st gear when I floor it from low revs, but that is when parts are under most load I assume?? If the box is knackerd is it just a refurb I need?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Can you get a sound clip up?
    Feb 2011
    Somerset
    240
    Chipped tooth in the box could be the prob, if its only in some gears and not others.
    Mar 2011
    22
    How much would that cost to repair? Is it a full recon?
    Feb 2011
    Somerset
    240
    Probably alot cheaper to get a second hand unit if you can find one.
