Chris NottSky Insurance
Results 1 to 9 of 9
    Mar 2011
    Warrington
    10
    New clutch fitting problem
    I got an ESC stage 1 clutch and light weight flywheel for my 1999 A3 1.8T
    Got the gearbox out and new clutch fitted no problem. I now have the gear box about 10-15mm from where it should be and it will not slide towards the engine. It's square and I can get long bolts through all the holes. Don't want to tighten them incase I crush something. But it just will not slide back on like it came off.
    I even resorted to the Haynes manual and seem to have done everything in there.
    Has anybody got any ideas.
    Thanks in advance.
    KB
    KB's Avatar
    Jul 2010
    Inverurie, Aberdeenshire, United Kingdom
    195
    19mm spanner on the bottom pully and turn it to turn the engine ever so slighty so the output shaft lines up in to the box?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    what did you use to align the clutch?
    Mar 2011
    Warrington
    10
    Used an alignment tool that came with the clutch kit.
    I tried putting it in gear and turning the drive shaft slightly. Would that achieve the same as turning the engine?
    beachbuggy's Avatar
    Surrey
    1,741
    That way would only work if one wheel is on the ground and not able to rotate. If they are both up and free to spin, then you turn one and the other will turn the other way and not turn the engine over. If as you say it's 10cm out then the splines and grooves aren't lined up.
    Mar 2011
    Warrington
    10
    Quote Originally Posted by beachbuggy View Post
    I'll turn the bottom pulley in the morning and see what happens.
    Thanks.
    London
    160
    buy the way before you bolted the clucth plate onto the flywheel did you try to slide the clucth plate on the gearbox shaft to see if it goes on?
    Mar 2011
    Warrington
    10
    Sorted
    Mar 2011
    Warrington
    10
    Took it all apart, re-did the alignment, hung the gear box from an engine hoist, turned the bottom pulley and it slid straight back on.
    Thanks to everyone for the advice.
