Chris NottVolks Autos
Results 1 to 8 of 8
    Aug 2010
    s3 top middle airvents question ?
    how do you remove it without getting dents from a screwdriver all around it ? thanks
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    I know how to get the slots. There might be some screws behinds the slots, but not sure how to get the actual vent out completely.
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    No screws mate, I removed all the 'slats', there's two sets in there on each side. Once removed, I put my hand in and yanked it out. ELSA states that the vents can be pulled out using a 'U' shaped tool, I didn't have one so went down the usual drastic route!
    Don't forget that there will be some cabling that is attached for the illumination too - remove the cover under the steering wheel and lie in the footwell with a torch to locate it after loosening the vent (you'll be able to see where the light seeps through). Good luck!
    Imteyaz.
    Aug 2010
    cheers what light are you talking about its only the air vent ? what lights up onit ?
    and how do i remove the slats without breaking them ?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,178
    There will be little connectors for the lights in the wheels that open or close the vent, they light up red remember
    You can remove the slats by bending the slightly and pulling them. They are only held in by tiny bits of plastic at each end. Don't be too fragile with it, they're quite strong.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Aug 2010
    Quote Originally Posted by Westle View Post
    thanks mate and ive got a gauge pod that fits perfectly where the vent is could i use the wiring from the vent to power my gauges ? or would they only come on when i put the lights on ?
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    They only come on with the illumination mate, I would run a little exta wire (using an in-line fuse) direct to the fusebox where you can find a IGN controlled 12v+.
    Imteyaz.
    Westy's Avatar
    Dec 2008
    17,178
    I plumbed my guage into the switch for the lights to the right of the steering wheel. I've wired it in so that it comes on with ignition and stays on.
    S3 Build Thread
