[ QUOTE ]
AndyMac said:
Is it the original Concert head unit?
If so it is most likely the antenna amp. Depending on the year, most A3's have the amp in the head unit. Early models had the amp in the bee-sting aerial base, but when these amps started to fail it was a major job to strip the headlining and replace the aerial that they changed it for the HU amp. I would buy the external antenna amp and just give that a try as it is relatively cheap and easy to fit, otherwise you're looking at either replacing the bee-sting or the HU, neither of which are particularly cheap.
[/ QUOTE ]
My A3 is a Y plate 2001 and it is still the original unit so do you think i could get away with the cheaper of your options?If so,where is the best place to get the external amp and what is the process to fitting.I love my car but when it comes to doing things other that changing a bulb then im at a loss.
Thanks for the help so far btw.
