EM TuningBadger5
Results 1 to 11 of 11
    imported_SYNAPS3
    Fuel Pressure Regulator
    When would you upgrade your FPR and why would you do so?
    Also, if your S3 fuel pump operates at 3 bar can you use a 4 bar FPR.
    Guess, i am asking how a FPR works ?
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: Fuel Pressure Regulator
    [ QUOTE ]
    [/ QUOTE ]
    The S3 fuel pump runs at 5 bar therefore 4 bar is within its reach. running a 4 bar FPR over the 3 will increase fuelling, but wont necessarily give more power.
    RIch
    ...Watching you!
    Earlsfield, London
    5,087
    When you say your using a large bore MAF, what car is it from and what size is it?
    Rich
    imported_SYNAPS3
    [ QUOTE ]
    s3ugly said:
    mine was 3bar originaly
    [/ QUOTE ]
    Mine is also 3bar....
    Oct 2004
    13
    [ QUOTE ]
    Rich
    [/ QUOTE ]
    its the BAMM ,a thinwall stainless custom made, same external diameter,so theres no install problems on TIP. but the same size internal as an s4 maf, smoother flow and no screens 18% more flow than standard
    ...Watching you!
    Earlsfield, London
    5,087
    Ah ok. Im having one custom made from aluminium. Im using a modified TT MAF housing at the moment but its not tidy enough for my liking so going for an all alloy one. should look nicer and flow better too.
    Rich
    Oct 2004
    13
    how much does your one cost? what TIP are you using whith that IHI charger?
    ...Watching you!
    Earlsfield, London
    5,087
    Is that a boost valve behind your airbox too?
    Rich
    Oct 2004
    13
    yeh its an adjustable "boost machine", the filterbox is a custom made twin entry heat insulated carbon fibre box a guy in the states makes all sorts of stuff like this, and with the exchange rate at the moment it works out resonable
    ...Watching you!
    Earlsfield, London
    5,087
    Whos the guy? does he have a site?
    Rich
    AndybS3's Avatar
    Jun 2003
    Central Scotland
    233
    His username on Audiworld is TTSchwing
    http://public.fotki.com/ttschwing/ttda_and_other_inta/
