Badger5JMB Retrofits
Results 1 to 19 of 19
    S3 Paul's Avatar
    Oct 2006
    2,764
    Great, Major mardy on the cards, !
    So... i drive my car thinking... you know what, i finaly think ive got on top of the jobs needed to be done ... i get home, park up and half hour later spot coolant on the floor ! deep joy, But this is where the real story begins... I lift the bonnet and look for the leak,
    Firstly i find a new issue. Dodgy looking grease/thick oil on top of the bell housing end of the gear box.
    Quite a bit ( about as much as you would expect if a cv boot had gone ) but there is nothing that holds grease around there,
    Then i notice the grease is around the hole in the gearbox bell houseing where you can see the flywheel, The car drove completely normaly with no clunks or no dodgy set offs that ive been told go with a "shagged flywheel"
    I think ive found the water leak too. will post a picture of where i think thats from.
    Is the grease from the duel mass flywheel?
    Does this now mean i need to replace the clutch and flywheel?
    They where both fitted about 18 months ago. luk flywheel and sache power clutch.
    Noggy Blue 2001 S3
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    Not 100% sure but if you had grease on the flywheel wouldnt have immense clutch slip?
    S3 Paul's Avatar
    Oct 2006
    2,764
    Thats what i thought.
    Or can it come out of the rear of the flywheel meaning it hasnt come into contact with the clutch?
    The ring gear of the flywheel is clean and dry to be honest.
    Noggy Blue 2001 S3
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    It's definitely not coming from the rocker cover?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    wibble111's Avatar
    Nov 2006
    derbyshire
    829
    I'm pretty sure there should be no grease inside the bell housing just incase it came into contact with the flywheel surface, I'm not 100% sure though so could well be wrong.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Thats what i would have thought the half moon gasket thing....from the rocker
    Westy's Avatar
    Dec 2008
    17,280
    When there's oil down the right hand side (as you look into the bay) and on top of the gear box it's normally the cam adjuster gasket, or "half moon thing" as you put it Dave
    S3 Build Thread
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Sounds like either the half moon gasket or it could be one of the oil breather pipes what's been disconnected for a while allowing gunk to drop onto the gearbox
    S3 Paul's Avatar
    Oct 2006
    2,764
    Nah, the "stuff" is thicker than dirty oil to be fair. takes alot of wiping off of my hands and such. Feels more like grease to me... im told the flywheel has greasey stuff in as a damper??
    Noggy Blue 2001 S3
    Westy's Avatar
    Dec 2008
    17,280
    Quote Originally Posted by S3 Paul View Post
    Try giving it a spray with some degreaser and a blast with the jetwash then keep an eye on it and you should be able to see where it's coming from.
    S3 Build Thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yes but it could be emulsified oil from the rocker, whatever it is i hope its not to expensive mate...
    S3 Paul's Avatar
    Oct 2006
    2,764
    Oh i fear it will be.
    I never have quick fix problems.
    I know the rocker is leaking a little but not much to be honest. ive cleaned both and cleaned up the coolant leak to see whats what in the morning ( after a drive to work )
    Noggy Blue 2001 S3
    S3 Paul's Avatar
    Oct 2006
    2,764
    This is where i think the coolant is leaking from... it was a bugger to find but this is where its wet as aposed to just covered in coolant...
    This is on the gearbox end of the engine. i think the pipe im pointing at goes down to the oil cooler...
    I think or should that be i hope... its just the spring hose clip thats leaking... is this likely???
    Noggy Blue 2001 S3
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Wheres this hole paul where you can see the flywheel? Its just i have a hole where i can see a cog (believe this must be the flywheel) but i have no plug for it!
    Westy's Avatar
    Dec 2008
    17,280
    That's the pipe under the temp sender. I think you'll have to drop what's left of your coolant and get that hose off for a closer inspection. You want to get that sorted before the warm weather comes back.
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Perished pipe maybe, those clips I find are pretty strong. I
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    the starter motor has thick grease in doesnt it? Does it sound ok?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    It looks like the clip has perished the hose,
    S3 Paul's Avatar
    Oct 2006
    2,764
    I removed the hose today... the hose looked ok to be fair so i refitted it with a juberle clip but still the drips came,
    I then decided to remove the housing.... there is a crack where the seal sits... im hoping this is the problem,
    A new one will be ordered tomorrow
    Regarding the clutch issue, Im advised this will be the "stuff" from inside the flywheel. So it looks like i need a new flywheel and clutch,
    Im thinking new duel mass and the same combo as tuffty and Pat... Basicaly a standard cover with a sache 4 puck paddle clutch drive plate.
    Is this right? A good set up ?
    Noggy Blue 2001 S3
