AH FabricationsChris Nott
Results 1 to 8 of 8
Thread: OH CRAP!!!
    A3tell's Avatar
    Jun 2009
    essex
    239
    Angry OH CRAP!!!
    why.............. finally got booked into r-tech, and the damn car broke down!!!!
    looks like a corroded water pipe let go, and blew a hole in it! and it happens to be one of the metal pipes that go into the block!!!!!! so have now got to run around to try and get it sorted before my r-tech appointment!!! am guessing its not going to be a cheap or easy fix???
    dont suppose anyone has any knowledge of part numbers for the water pipe that runs under the inlet manni near the the thermostat housing????
    Jan 2011
    Kent
    201
    thats unfortunate mate
    how long u got until your meant to be at r-tech..
    at least it didn't happen on the way to r-tech
    Apr 2010
    Widnes Cheshire
    404
    Hard luck, if you go to your local Audi they can bring up a diagram from which you can identify the pipe. Yeah it aint going to be cheap!!
    DC
    His: 2001 1.8T AUM. Hibiscus Red Pearl Effect - Hers: 2002 1.8T AUM. Metalic Silver.
    It's all in bits
    Apr 2006
    Bristol
    219
    The hard pipe that runs across the front of the block?
    Whats your engine code?
    A3tell's Avatar
    Jun 2009
    essex
    239
    yeh thats the one! agu engine.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,372
    mine cracked due to rust too mate, I just cut out the rusty section, and replaced it with 4'' of silicon hose.
    Much quicker, and MUCH cheaper than replacing the whole pipe, and it'll get you to your appt.
    I think when I looked into the pipe from audi it was around 100!
    It's all in bits
    Apr 2006
    Bristol
    219
    Probably this one then, but double check with Audi as won't be cheap! Or use a breaker.
    A3tell's Avatar
    Jun 2009
    essex
    239
    thanks!! did you have to remove the pipe?? was it easy?? didi you have to take anything off to get to it???
