creaking noises
scotty_24
Newcastle upon Tyne
Hello, I have a 51 plate S3 which has some creaking and groaning issues.
when coming to a stop and braking lightly, i can hear a "errrrrr eeee errrrrrrr eeeeee" noise which sounds rotational coming from the passenger side front.
Also, when going over speed bumps I get a creaking from the rear, which makes the same noise as a parcel shelf jumping around in the back. I took my parcel shelf out to make sure it want that!
The noises have got my head done in, please help!
you just need to grease/oil your arb bushes, drop links & suspension
Hmmm ...
I wonder if this is down to the weather as I've been having the same problems and doing a bit of searching showed up a lot of recent threads from people having the same issue.
I found this:
http://www.wak-tt.com/antiroll/antiroll.htm
I know it for a tt but the principle is still the same.
I went to halfords and it seems they have stopped selling the “nylon/rubber lube” so i had to buy this:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_219033_langId_-1_categoryId_165705
I think its the same thing only re packaged.
Ill let you know how i get on ;)
i get this only going round left corners and going down bumps slowly just booked car for new suspension as i h8 the s3 suspenion not stiff enough will give the grease a go and hopefully will last till 11th june till get full ap coilovers, new tie arms and full bearings and top mounts all round.
Anythings worth a try, if it is the ARB bushes Is it worth getting powerflex ones?
yeh as standard ones will go again eventually the powerflex ones will last a lifetime
same problem here, changed all my bushes about 6 months ago so I think the weather over Christmas might have done some damage!? Got some of that original silicone spray somewhere gonna give that a shot.
found my problem rear drop link has gone jacked car up and it was waving at me saying help me so gonna tie wrap it in place for now
I sprayed all my bushes and still got a creaking noise over bumps. All droplinks look ok, what else could it be?
Is everyone using the halfords silicone grease i posted up?
I've not had time to do mine yet but i think when i do ill use the straw that come with wd40, to really get in there....lol
