EM TuningSky Insurance
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    How to remove rear bumper.
    Starting with the rear end
    Jacked up and ready to start:
    Firstly you need to remove the black plastic trim along the top edge of the bumper:
    Remove this screw:
    And also this screw:
    Now you can remove the small piece of trim. Note that it is only the right hand side piece that is removable:
    You can now carefully lift the trim up, if this is the first time it has been removed you will need a knife to cut the silicone which glues it down. The trim is also held in place by velcro strips:
    Now that piece of trim is out of the way we can remove the metal bar and the 6x screws that hold it in place:
    Now you can turn your attention to removing the 5x screws that hold the bumper on in the inside edge of each side of the wheel arches. My rear shocks look a state in this picture, the covers have rusted away.... another job on the list of things to replace:
    Now remove this screw on the under side:
    And finally the last screw to be removed hides on the underside between the exhaust tips:
    The rear bumper should now just pull off with a gentle tug. If you have rear parking sensors you will need to be carefull when removing the bumper as there isn't much slack in the wiring, you will need to pull the bumper off far enough to get your hand behind and cut the cable ties holding the loom to the inside of the bumper and then unplug each individual sensor:
    Here's what it looks like with the bumper off:
    Info was taken from Agric04's Towbar install thread below.
    Latest performance mod!! S3 8L Westfalia detachable towbar install
    Cheers.
    You've got to have a laugh!
    Wind Deflector Trend-setter
    Nov 2011
    Horsham
    386
    Thanks for this helpful guide. I'm removing mine today and this is very useful.
    2000 Plate Audi S3 1.8T Santorin Blue - 275BHP on Custom Parsons Performance remap, Forge 007p DV, Red DogBush, Milltek non-res, Lowered 35mm Apex springs, Badger5 TIP/cone filter/heat shield, Powerflex'd, Large FMIC, Relentless Downpipe, Parsons Decat and lots of love.
    On gearbox number 4.
    Further modification to come..
