EM TuningChris Nott
Results 1 to 9 of 9
    AudiiduA's Avatar
    Midlands
    358
    N/A Injectors?????
    Hi all, has anyone the part no for and AMK S3? also are the injectors different on an N/A car??
    thanks fellas
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Don't have the part numbers off hand but can tell you that the injectors are way different... what is it you are trying to do exactly? I have noticed you have started several threads when it may be easier to pull it all together in one build thread if thats what you are doing...
    <tuffty/>
    AudiiduA's Avatar
    Midlands
    358
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Hi tuffty, your a very helpful guy, thanks....
    i wasnt planning a build but the S3 i just bought was supposed to be standard! since i bought it its been well down on power! no boost at first! seems someone was doing a rolling project as its got different head and cams and poss ECU, injectors possibly? so im playing catch up really, trying to find out what parts are what! even the block says 08A Not 06A??? im baffled! car used to be owned by S3Chris from on here, but he aint been on here for about 2 years and its had 2 more owners since! i changed coil packs tonight and a massive difference in performance! but still not where it sould be! i have replaced MAF, N75,irridium tipped plugs,airfilter, oil filter,oil, new TIP, several boost leaks sorted but still more i fear! injector seals, knock sensors!
    the car was going into limp mode with code 16711, so must have been pinking, so tomorrow boost leaks being sorted and codes cleared and injectors cleaned! but need to find out if the ones in are for an S3??
    So thats why all my posts! i havent had it running right since i bought it and determined to sort it before my remap!!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    Dont judge the book by the cover springs to mind here then, as it was an exceptional looking car...
    AudiiduA's Avatar
    Midlands
    358
    Did you know this car then Dave?? still is very nice looking and spec! may have to get it custom mapped with whats been done? may take it further now and get front mounted intercooler ect! the cams that are inhave a longer duration and a higher lift so will need a custom map i think????
    Lee
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    If you whip the injectors out and get the part number off it, we'll be able to see if its correct.
    You dont generally fit longer duration cams to a turbocharged engine, so i'd be wanting to know exactly what they are and where they're from.
    TD5 Land Rover Defender build
    AudiiduA's Avatar
    Midlands
    358
    Quite true Aragorn, was told on here that a few had used N/A cams to gain more power though! not 100% that mine are N/A, i got to get time to whip cam cover off! the way it runs im not sure, very smooth at idle!
    will be very nice when it 100% as i have replaced everything lol, should run for years lol
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    Quote Originally Posted by AudiiduA View Post
    Lee
    Not personally no but seen plenty of pics of it:
    part number for injectors are: 06a906031bc
    AudiiduA's Avatar
    Midlands
    358
    post some more soon, and cheers for the p/n
