Chris NottAH Fabrications
Results 1 to 25 of 25
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    Westle and S3baby's late night mechanics. (Replacing Alarm Batteries)
    Right just got all the boot trim off to tackle this ***** and I'm now after some guidance!
    Can anyone confirm that the alarm and the batteries are actually part of the central locking pump???
    I've plugged in the laptop and triggered the alarm and it seems to be sounding from the central locking pump. This is slightly different to the TT, as seen in this guide:
    The Audi TT Forum :: View topic - How to - MK1 Alarm Siren fix
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    Not part of the pump as far as i know... i've had the pump out in the past and it has nothing to do with the alarm... sorry i can't help you any further... my car had an uprated alarm fitted by Audi so i don't use the standard one anymore
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Westy's Avatar
    Dec 2008
    17,280
    It's ok i've just found the siren. Little fecker is dug in tight!
    Picks to follow
    S3 Build Thread
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Watching this one.... I'm getting 3 beeps when I start my car now from the back which I presume is the alarm batteries being on their last legs
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Mar 2008
    Oldham, Manchester
    1,110
    Under the Sub is it ????
    Breezey's Avatar
    Hexxagon Champion
    Mar 2010
    Bridgwater
    433
    its under the sub yes but further down basically attached to the inside of the rear bumper almost.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Cool, I've got to take the trim off the inside of my boot anyway as I found the spare wheel well had washer fluid in it so the washer hose under the subs leaking, might as well do it all when I'm down there!
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Easy to do, just follow this link:
    Did mine a few months back when the dreaded "3 beeps" started. All sorted and tested with the old "wind the window down, lock the car and wave your arm in" approach!!!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Cheers doc, stored for future reference.....
    Westy's Avatar
    Dec 2008
    17,280
    I posted the exact same link in my first post!
    S3 Build Thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    cheers missed it...lol
    Westy's Avatar
    Dec 2008
    17,280
    Ok here's the guide for an S3 with the Bose sub:
    I was suffering from the occaisional 3 beeps from the back of the car and also the following error in VCDS:
    01134 - Alarm Horn (H12) 01598 - Drive Battery Voltage 077-10 Signal low Intermittent
    First off open the boot (obviously) and undo the 4 torx (size 25) bolts inside the boot trim near the warning triangle:
    Next up you will need to unscrew the 2 torx bolts (size 27) that are under the spring clip of the luggage net holdings. There's one each side:
    You can then remove the bottom part of the boot trim:
    Now remove the side panel that lets you into the compartment above the passenger side rear wheel arch. If you look in and up towards the rear light cluster you should see a screw head that's holding a bit of plastic trim, like so:
    As you can see I have broken the plastic at some point when I forgot about this screw!
    With this screw out just grab on tight and pull at the trim and it will come away:
    Now I found things a lot easier if you put the passenger side rear seat forward and lift the carpet. Then undo the luggage net clip that is behind the passenger seat:
    Now move the central locking pump out the way, it might be cable tied in so cut the tie. With this out the way you will be able to access the bolts that hold in the sub as seen in the following pics:
    Undo the 3 bolts (8mm I believe) and unplug the sub:
    You then need to undo the bolts holding on the little amp for the rear speakers that sits above the sub:
    This will then swing out of the way:
    You can then swing the sub out the way too:
    The siren is tucked down real low below where the central locking pump was originally:
    There is one 10mm bolt that is on a brass bracket, undo this and you can slide out the alarm siren on the bracket:
    With the siren out I set to work on it with a junior hacksaw. I didn't have any cutting discs for the dremmel and I thought it would be a lot more controlled with the hacksaw:
    Unfortunately the batteries had already started to leak and the damage was quite bad but I had a go at repairing it anyway. The tracks on the board were also damaged from the acid:
    I set about following the guide above and wired up the batteries to the board after a little clean up of the acid:
    I put the alarm casing back together and taped it shut, reconnected it to the car but it is now a silent alarm MY error message has now cleared though so the batteries were definitely the cause but I think the board tracks were too damaged. New alarm module time for me.
    Hopefully you can catch yours before it's too late!
    For anyone wanting the original part number here it is:
    S3 Build Thread
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    I'm gonna have to do mine at some point! It started bleeping from the rear speakers last summer for a couple months but then it stopped doing it. What happens if you don't change batteries and you leave them dead?
    I may take a trip to you sometime mate Are you anywhere near the Hertfordshire Police Constabulary?
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    Westy's Avatar
    Dec 2008
    17,280
    You will get away with it for a while but I the batteries completely split then it will kill your alarm. Mine has been beeping on and off for 2 years now and I killed my alarm module by cleaning it up so sometimes it is just best to leave things as they are!
    Which police station are you referring to?
    S3 Build Thread
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Quote Originally Posted by Westle View Post
    Bugger, i better get it sorted soon then! I mean the Herts Police HQ.
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    Herts Police HQ is in Welwyn Garden City.
    Me and Westle are about 20 min from there.
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Could these pics be put back up - trying to get the alarm out. Have the sub removed and the rear cluster out but can't find the 10mm that holds the unit in place grrrr! lol
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Cancel that, got it in the end, what a little sod of a position to put it in grr lol!
    Westy's Avatar
    Dec 2008
    17,280
    Quote Originally Posted by SiGainey View Post
    Only just spotted this sorry bud. I'll fix the links now.
    S3 Build Thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Sorry for a thread revival but i need todo this. I cant get my head around how to connectthe batterys together and wiring them in, can anyone explain it in a simpletons terms, wiring isnt my favourite job in the world.
    Westy's Avatar
    Dec 2008
    17,280
    I wouldn't bother with this mate, just buy a new alarm module. Normally if you've been getting the 3 beeps of doom the PCB board has probably already bit the bullet.
    S3 Build Thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    I got the 3 beeps about 2 years ago just never got around to doing it haha, guessing mine will be well shot now.
    Westy's Avatar
    Dec 2008
    17,280
    Definitely mate. By all means cut it open and take a look. My PCB board was melted from the acid and the damage wasnt fixable. I tried the new battery trick anyway and it did nothing. I fitted a 2nd hand alarm and that lasted about 6 months and has now gone silent after a month of beeping.
    If you order a new module from the stealers it's a revised part that is meant to be louder and last longer.
    S3 Build Thread
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    621
    Does anyone know how much a new module is from the stealers as mine's been bleeping for a while now but it still bleep when locking/unlocking.
    Westy's Avatar
    Dec 2008
    17,280
    Quote Originally Posted by S3 TAM View Post
    Ask Jason matey.
    S3 Build Thread
