Sky InsuranceAH Fabrications
Thread: Oil
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    Oil
    what oil u fellas using ???
    just topped up with some Castrol SLX 2 synthetic (0/w30?)as my engine was bone dry
    not a fecking drop in it
    thinking it will need more than the 1 litre i whacked in last nite
    this is pretty expensive oil the synthetic stuff (app.esp for VAG engines with AVS service intervals)
    40 quid for 3.5 litres
    this what u all using ????
    nervus's Avatar
    Apr 2004
    1,160
    Re: Oil
    Mobil 1,
    It is expensive but not as much as an engine rebuild!
    imported_gek
    Re: Oil
    Castrol SLX 49 for 4 litres from Halfords [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Oct 2003
    South Wales
    2,942
    Re: Oil
    I use Mobil 1 also.
    Its cheaper than Castol SLX at my local halfords and its VW503.01 approved for my AVS Servicing!
    I didn't think it was that expensive?
    Rich.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Re: Oil
    I'm using fully synthetic VAG Synta Gold - about 23 for 5 litres from GSF. It gets changed every 5000 miles as I'm not following the variable service routine as I don't agree with it.
    I've been advised that you only need the tip-top Castrol stuff if you are following variable servicing. If not, any quality synthetic will do.
