Badger5EM Tuning
    Jan 2004
    Cardiff, UK
    140
    N75J & Boostvalve Controllers
    Guys,
    Any of you running a N75J with a boostvalve controll fitted? The N7J gives a much more aggresive & smooth spool up of boost on my set up but is overboosting slightly. If I change back to my normal N75 the car is fine but feels so much more sluggish. The J on mine makes the car seem so much better up the boost range even when I tickle it upto just 5 psi. Having the throttle responce seeming much crisper when compared to the original valve I really dont want to fit the old one back if I have to. Any experiences or thoughts would be appreciated. N.B. the site for the boostvalve is below.
    http://www.boostvalve.com/
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: N75J & Boostvalve Controllers
    Mat,
    A few people have tried the boostvalve and said that it works very well with the 'J' valve. it *should* solve your problems!
    Rich
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    I use "The Boost Machine" where you can adjust boost pressure and also adjust the pressure relief as well.
    Some info from Wak's TT page:
    http://www.wak-tt.com/mods/boostmach...ostmachine.htm
    Oct 2004
    34
    whats the difference between the n75 and the n75j ?
    where can you get one of these from?
    Oct 2004
    34
    so whats a 710n bypass valve, on some sites this is quoted as a replacement item?
    Drill's Avatar
    Land of Good Beer, and better Roads :-p
    928
    That's the DV dude [img]/ubbthreads/images/graemlins/grin.gif[/img] 710N refers to the end of the part number [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
