Chris NottSky Insurance
    AudiiduA's Avatar
    Midlands
    358
    Any Auto Electicians in Midlands?
    I have fault code 16711, seems that its the wiring, so anyone good with electrics?
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Whats the problem that you are having and where in the mids are you??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    16711/P0327 - Ross-Tech Wiki
    16711/P0327 - Knock Sensor 1 (G61): Signal Too Low
    Possible Symptoms
    Irregular rpm
    Drivability problems
    Loss of power
    Engine damage
    Possible Causes
    Circuit G61 short to Ground
    Circuit G61 open
    G61 improperly torqued
    G61 damaged
    Control Module damaged
    Possible Solutions
    Torque Knock Sensor 1 (G61) to specifications.
    Check wiring and connections
    Check Knock Sensor 1 (G61) and Knock Control
    Special Notes
    This feature search for unusual (spontaneous) combustion. The sensor detects unusual vibrations and based on that it generates a voltage. Is this voltage outside a certain limit a dtc will be set.
    Might be worth swapping the wires over briefly to see if the fault follows it... if it does it likely to be the wiring, if it doesn't then the knock sensor prob needs replacing...
    I had a signal too high fault on mine and just rewired it to the ECU...
    <tuffty/>
    <tuffty/>
    AudiiduA's Avatar
    Midlands
    358
    Quote Originally Posted by nilz18t View Post
    Im near the NEC Birmingham!!!
    As tufftybloke found, its a knock sensor fault! i have replaced both knocksensors and torqued to 20NM
    Signal to low, throwing my car into limp mode! im no good with wiring!!
    Cars runs nice but little boost due to limp mode! i have a code reader and have cleared fault but just comes straight back!!! not had the car long, about a week! and not had it running right yet. spent a fortune already on it!!
    AudiiduA's Avatar
    Midlands
    358
    Quote Originally Posted by tufftybloke View Post
    Possible Symptoms
    Irregular rpm
    Loss of power
    Engine damage
    Possible Causes
    Circuit G61 open
    G61 damaged
    Possible Solutions
    Special Notes
    <tuffty/>
    <tuffty/>
    It mentions a control module, where is it on the car and how much??
    Pulling my hair out with this now!!!
