Monster MotorsportEM Tuning
Results 1 to 8 of 8
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    Few bits done today!
    Evening all, got a few bits done on the car today, new fuel filter, new top mounts and bearings, nsf outer cv boot, red poly dog bone mount and the 249 bypass and replaced the pipe into the fpr with some red silicone vac pipe.
    What can i say, the car feels soooo much nicer to drive now, everything feels a lot more tighter and responsive, the vibration from the dog bone is very minimal, only really noticeable when lifting the clutch really and my reverse gear selection is now far far better.
    Only problem is I still have a very slight knocking from the osf still but nowhere as bad as it was, anyone got any ideas what else it could be?
    Cheers, Dave.
    Ashley g's Avatar
    Feb 2011
    High Wycombe Bucks
    178
    Good work! What benefits are there to doing the 249 bypass? Knocking noise could be an anti roll bar link, give them a good pull up and down to see if there's any play.
    2003-03 8L S3 Dolphin grey - Porsche 996 calipers - Mo-vit 325mm 2 piece front discs - 15mm spacers all round - Miltek resonated cat back - Genuine RS4's - Vredestein Sessanta's - Forge 007p - Forge TIP - JR cone filter - Poweflex diesel dog bone bush - AMD Remap - Blue Haldex controller - FK AK Coilovers - Seat Leon Cupra R top mounts - 8P S3 gear knob and gaitor - TT pedals - Neuspeed quick shift - LED number plate bulbs
    14.2 quarter @ 97 mph
    Power? 241 bhp with a boost leak, now fixed
    wibble111's Avatar
    Nov 2006
    derbyshire
    829
    With the 249 bypass i had a broken 'T' in the pipework then had an eml, did a scan and it came up 249 mechanical malfunction so i thought i'd take the pipework off as it was cheaper than replacing with oem stuff, but from what i have read it sharpens up the dv response, tbh i cant really notice any diffrence between standard but i cleared the code did the bypass and the fault hasnt come back, yet.
    I thought maybe the arb link but would you still get play in it with weight on the wheel or do i need to jack it up and try?
    spencer-s3's Avatar
    2nd gear
    Oct 2010
    Bridgend, United Kingdom
    63
    Front top mount common fault
    S3 Top Mounts
    Agric04's Avatar
    Feb 2011
    Grantham, Lincolnshire
    198
    My money on the knocking noise would be on the front arb bushes, if the coating on the arb bar is also broken you may also need to replace this at the same time as the bushes so they sit on the bar correctly.
    I replaced all my top mounts, wishbone bushes and arb bushes with super pro ones last month last month because it was knocking. Not a peep from it now. Its as good as new again.
    Changing my fuel filter this weekend, any tips I should be aware of or is it dead straight forward. I am assuming it's dead straight forward!
    wibble111's Avatar
    Nov 2006
    derbyshire
    829
    Quote Originally Posted by spencer-s3 View Post
    S3 Top Mounts
    Changed them today mate as i had quite a bad knocking which has now gone but there is still something knocking
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    My car clunks Shen I do a 3 point turn I have full polybush kit to go on on Friday or as much as is possible.... Back on the rollers Saturday for the full medical.....
    S3 Owner
    Feb 2009
    Aberdeen
    414
    I had the same thing and it was indeed the ARB bushes.. Cheap to buy and my mechanic had them fitted in 20 minutes!
